ABS Sensor
Old Feb 10, 2016 | 12:51 PM
416tt's Avatar
416tt
Default ABS Sensor
Hi,
so my front right abs sensor has went bad... i am trying to order a sensor from rock auto but wondering why there is two different types available?
OEM: 89542 30160
Aftmrkt: ABS806 or ALS696
1) under speed sensor category you see ones without wires:
2) when i type abs sensor i get these full sensor with wires
i was assuming abs sensors on SC come as one piece right? the wires dont seperate from the sensor? unless sensors in 1) are for some other area on the car
Thanks guys
Old Feb 10, 2016 | 12:57 PM
416tt's Avatar
416tt
nvm figured the ones in 1) are for a transmission....
dont know how to delete this thread...
Old Feb 10, 2016 | 05:11 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
What are the symtoms of it going bad and did you recently have any front end work performed?
I ask because I had an issue right after I replaced a bunch of parts on my front end.
I did a battery disconnect/reconnect and everything was fine again
Old Feb 11, 2016 | 08:13 AM
416tt's Avatar
416tt
thanks for the reply
I had spc ball joints changed and lower ball joints changed and after that light came on including vsc ones
Old Feb 11, 2016 | 10:03 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
When it happened to me, I
removed the one screw holding the sensor,
pulled it out,
wiped the grease off the end,
reinstalled,
Disconnected the battery terminal for five minutes
Reconnected,
Reset the codes using my code reader and reset the lights by shorting OBDII pins 4&14.
No more issues
Did you address this problem, in another thread several weeks ago, or did this just happen?
Old Feb 16, 2016 | 08:42 AM
416tt's Avatar
416tt
pulled it out,
reinstalled,
Reconnected,
No more issues
I actually cleaned the sensor myself too but did not unplug battery so ill try that.. and yes i previously brought it up but that was for the knock sensor which also brought up the VSC lights, thats gone and now its the abs light causing it.
but ill try disconnecting terminal for a few minutes. thank you!
keithd60
Oct 25, 2013 03:06 PM
islexusred
Apr 7, 2012 07:53 AM
Sooner1971
Jul 23, 2011 04:45 AM
GS4nicate
Suspension and Brakes
Sep 29, 2010 02:51 PM
daintyboy
Jan 8, 2008 09:41 PM
