Car Bogging Down
Old Feb 5, 2009 | 08:18 AM
eyeain's Avatar
eyeain
Default Car Bogging Down
I wonder if some one can help i have a 2002 SC when coming to a stop and then accelerating the car hesitates for few seconds before taking off its scary when getting on to highway.
Once it gets going then its smooth.
Old Feb 5, 2009 | 09:39 AM
PHXSC's Avatar
PHXSC
You may be experiencing the lag that is inherent to all of these cars, due to fly-by-wire throttle system. You may want to try putting your car in the "Power" mode. I found this helps a little bit - at least it seems so.
There is also a mod you can do with a Blitz controller that eliminates the lag.
Old Feb 5, 2009 | 09:55 AM
eyeain's Avatar
eyeain
Many thanks for your comment but i feel its more then the famous initial dead spot.very distinct hesitation.
Old Feb 5, 2009 | 11:44 AM
CAMAracer's Avatar
CAMAracer
Have you done any recent changes to the engine/car?
Old Feb 5, 2009 | 09:13 PM
eyeain's Avatar
eyeain
Default Bogging Down
Only changed the plugs but that was done to check it may make things better but didn't help
Old Feb 6, 2009 | 04:27 AM
CBG's Avatar
CBG
What year and how many miles on it? Have you tried adding fuel injector cleaner to the gas tank? Just something you might try for a "cheap" fix.
Good Luck, Cliff
Old Feb 6, 2009 | 07:49 AM
Habious's Avatar
Habious
It also could be the Throttle Position Sensor.
Pearlpower talked about it in another thread...check this out and see if it sounds familiar. May require a trip to the dealer to fully diagnose.
https://www.clublexus.com/forums/2582020-post2.html
The full thread is here but, there's not much other useful information in it.
Old Feb 6, 2009 | 11:05 AM
aquanuke's Avatar
aquanuke
What grade fuel you using?
Old Feb 6, 2009 | 01:19 PM
da-bizket's Avatar
da-bizket
The "VSC" switch will bog it down. Try turning it off when your really getting on the gas.
Old Feb 7, 2009 | 09:22 AM
eyeain's Avatar
eyeain
Its a 2002 with 38000 miles i normally use 97 some times 95 and yes putting VSC off makes it better
my mechanic also advised injector cleaner if problem persists than TPS would be worth investigating.
Many thanks
Old Feb 7, 2009 | 05:34 PM
Harold57's Avatar
Harold57
It really sounds like the ECU has just reprogrammed its accelleration profile. Just run it in the power mode for two tanks of gas and it will likely get much better. (It did for me.)
SgtIk3
IS - 1st Gen (2001-2005)
Aug 15, 2016 10:32 AM
Boostd
Maintenance
Mar 18, 2012 10:07 AM
gs3exec
Jan 14, 2008 01:01 PM
aone
May 24, 2005 04:19 PM
