Navigation Help!
Old Jul 13, 2006 | 06:36 AM
TEXAS83's Avatar
TEXAS83
Default Navigation Help!
Alright, I need a favor. I bought a navi disc for my 2002 sc (generation 3) but it doesnt want to work properly. I need someone to send me an image of their navi disc update that works in their 02 sc. I will post an image of my disc just as soon as i get home, it says 05.1 on the disc but its acting funny. When you hit DESTINATION, it doesn't show the US map to change sectors and it can't locate any routes. But, when I went to check the DVD version, it clearly showed 05.1, but didn't have a year listed. When I popped my 02.1 disc back in last night, worked like normal. THANK YOU THANK YOU. PLEASE HELP
Old Jul 13, 2006 | 07:33 AM
TEXAS83's Avatar
TEXAS83
Alright, so heres a picture of the disc thats acting screwy in my system. If you cant tell from the image, here are the relevant numbers...
(top right corner in green)
U 30
(bottom of disc)
86271-53020
464210-0629
DATA ver.05.1
(left side under TOYOTA)
copyright 2005 DENSO
Old Jul 13, 2006 | 08:20 AM
JCtx's Avatar
JCtx
My '04 car lists 'Ver.03.1' when I hit the 'DVD' button. Can somebody with an '06 tell us what it shows on your screen?
I know nothing about these things, but logic tells me your disk is for Gen5 then, no? I read Gen3 (ours) and Gen5 (newer cars) are made by different vendors, so discs are probably different.
Did you buy the disc from your dealer? Let them sort the problem out.
I'd think newer data versions for our Nav would read Ver.03.2 maybe??? Just guessing. Please keep us posted so we know what's the deal if we ever upgrade. Take care.
Old Jul 13, 2006 | 09:04 AM
rominl's Avatar
rominl
exclusive matchup
can you find teh part numbers? the number shown there doesn't look like part number
if i remember right the version number can sometimes be misleading, so i usually go with part number. if you look at part number, you need something that says 3x at the end, not 4x. 4x is for the gen 4 nav (which is for 05+ i believe).
since 05 lexus used a whole new system so the dvds are not competible.
i never updated my nav though so i don't have pics, sorry
Old Jul 13, 2006 | 09:11 AM
TEXAS83's Avatar
TEXAS83
The only thing that I forgot to mention was that there is a big "D" underneath the "U 30" on the right hand side. All number, I already posted at the top. I'm guessing that the disc I got was a gen 4 or gen 5 disc. I know my system is gen 3....
Old Jul 13, 2006 | 09:56 AM
whitels's Avatar
whitels
Your new DVD disc will NOT work on your SC. You need to have the DVD that has striping/lines across the front, with the polka dots on the side. I'll look for an image and post it here today.
Old Jul 13, 2006 | 11:57 AM
tfischer's Avatar
tfischer
25 Year Member
First, I have the latest DVD in my car and I'll get it later and check it against the photo above.
In the meantime, some of the info above is not accurate.
First of all, the '02 SC430 had a Gen 2 Nav System. If you bought it in '01 or early '02 you got Data version 1. In '03 sometime I upgraded to data version 2. In Jan of '06 I upgraded to data version 5, which is the most current version (5.01).
The '04 Lexus had the Gen 3 NAV system - this refers to the hardware, not to the data. I don't know whether the '03 had the Gen 2 or Gen 3 system, but both the Gen 2 and Gen 3 systems use the same data disc. (How to tell: at the bottom of the Gen 3 Destination page, there is a small "home" icon followed by 5 numbered quick access icons -- The Gen 2 does not have this, only one big icon for HOME in the lower left corner; there are other differences, of course.)
The '05 SC went to the Gen 4 NAV system and I lost count after that, but I do know that it is from a different manufacturer and uses a different data disc.
So there could well be a version 2 data disc for the Gen 4 or Gen 5 NAV (I don't know how they number their data versions) that is not the same as the version 2 data for the Gen 2/3 systems.
As noted, the best way to tell if you have the right dvd is to check the Lexus Part number, which is not on the Disc or its package. However, the following Lexus cars have the Gen 2 or Gen 3 systems and will all use the same DVD:
LS 430 - 2001 to '03
GS 430 and 300 - '01 to '05
ES 300 and 330 - '02 and '03
RX 300/330 - '01 to '04
LX 470 - '01 to '03
IS 300 - '02 to '05
SC 430 - '02 to '04
GX 470 - '03 and '04
These are the cars with either a Gen 2 or Gen 3 NAV system.
Finally, when you press "DVD" or "DISC" on the menu system, it is telling you the data version, not the Generation of the NAV hardware.
Old Jul 13, 2006 | 01:02 PM
whitels's Avatar
whitels
The part numbers are:
86271-33034
464210-0640
DATA ver 05.1
The part number 86271-33034 tells me that this is a Gen 3 DVD (the first digit after the dash is 3). Your DVD disc therefore is a Gen 5 (86271-53020)
Notice also that the DOTS on this DVD are on the side, not in the center. And the stripes are predominantly obvious in the design. This is the DVD that will work in your system.
Old Jul 13, 2006 | 05:54 PM
TEXAS83's Avatar
TEXAS83
thanks everyone for your help, especially the guy who posted the picture. I will have to sell this disc on eBay now! can someone give me a list of cars that the DVD i have right now will work in. That way I can sell it correctly.
Oh and my car is strange. My car is '02, but the first date of use ever was February '03, I've confirmed this with 2 different dealerships and carfax. My factory warranty is still intact until then as well. So, my car has the gen 3 system with the home icon and 5 additional icons across the bottom for additional marked points.
Old Jul 13, 2006 | 08:09 PM
tfischer's Avatar
tfischer
25 Year Member
The '02 SC had a very long run.
I bought mine in April of '01 when they first went on sale (I got on a waiting list 18 months earlier; when I picked up my car, the dealer had 150 names on the list behind me). I'm not sure when the '03 models went on sale, but it's usually in Sept or Oct, although it did not make much difference because there were hardly any "model year" changes, and none of them were visible. (The basic rear bushings were changed, and the NAV went from an option installed at the factory on 98% of the cars to standard equipment, both at about this time -- nobody noticed. I think the spoiler was made standard, also, but I'm not sure.)
However, if your car's date of first use was Feb of '03, then my guess is that the dealer kept it on the lot for a demo. Most dealers kept one for this purpose, since the demand was such that all new ones coming onto the lot were already sold and all the buyers knew this and would not want even 10 miles on the car at delivery -- this was the case for about two years from April of '01. The dealers had to have something that prospective buyers could drive.
When a dealer sells a demo, the date of first use for warranty purposes is the date of sale, regardless of mileage, which is the only thing I can think of that would account for an '02 with a date of first use in early '03. And since this '02 model has the GEN 3 NAV, it's clear that the NAV was changed sometime during the '02 model run, which was 18 months rather than the usual 12.
So it's not that strange in light of the history of the first few years of sales.
Old Jul 13, 2006 | 08:45 PM
TEXAS83's Avatar
TEXAS83
Thats a good quality post! Makes sense as well, I was wondering why 03 Feb was the case. Thanks for the help!
Old Jul 14, 2006 | 06:11 AM
tonydt1g3r's Avatar
tonydt1g3r
I got an 02 that is just like urs the first navi disc I had in there is the same one your car came with. I upgraded to the latest DVD and it adds so many more roads in my area definently worth the $250 upgrade. Just shoot me an email if you want the contact info of where I got my DVD from. Also I have some older DVD's I think version 3 and 4 if your interested. Real cheap. Shoot me an email to tonydt1g3r@aol.com
Torben
Aug 7, 2015 01:59 AM
defo
Mar 16, 2013 05:49 PM
peteran85
Aug 19, 2010 05:00 AM
UCrazyKid
Jan 24, 2010 02:41 PM
