Window regulator fix for Sc models
Old Feb 7, 2009 | 01:23 PM
  #166
davidv433's Avatar
davidv433
i dont know why lexus used plastic in the first place but oh well, i guess ill be doing this fix myself too. drivers side went 2 days ago when in it was 20 degrees here in jersey.
Old Feb 7, 2009 | 01:42 PM
  #167
jgdynamics's Avatar
jgdynamics
does this work for slow passenger windows? mine seems like it struggles to go up and down at times.
Old Feb 7, 2009 | 02:17 PM
  #168
durtysc300's Avatar
durtysc300
i still couldn't figure out how to take the actual window bolts off..im gonna take it to a shop and probably just get a new regulator from gazi...it was movin slow anyway
Old Feb 7, 2009 | 02:36 PM
  #169
davidv433's Avatar
davidv433
Yup im gonna get one from him too, he's the man to go to for parts. but Im gonna try a to fix it anyway just to see. On the bottom of the plastic piece where it broke im going to clip a piece of lead to the metal cable instead of using jb weld like OLT did. Trying something different.
Old Feb 7, 2009 | 08:06 PM
  #170
TheMole's Avatar
TheMole
My passenger side is slow moving when it is near the top of the door. I think the rubber or rails just need some lubing.
Old Feb 10, 2009 | 05:57 PM
  #171
nnivlemm's Avatar
nnivlemm
I was going to tear into mine tomorrow, it shouldn't be too hard, just find all the bolts and take then out, but then again, we do drive SC's, and lexus doesn't like to make anything too easy. One of my friends with his s14 240sx took his door panel off in about 1 minute while I was trying to get mine off just to laugh at me. But I am much happier with my car than his.
Old Feb 13, 2009 | 03:23 PM
  #172
davidv433's Avatar
davidv433
i fixed my problem with a ring terminal connector a soldering gun and some solder. works awesome, anyone interested in how i did it i'll post pics if you want
Old Feb 13, 2009 | 03:43 PM
  #173
durtysc300's Avatar
durtysc300
how did you get the window bolts off?
Old Feb 13, 2009 | 03:48 PM
  #174
davidv433's Avatar
davidv433
vise grips and wd40 cus theywere rusted, right at the edge of the washer/nut with the 4 oval holes.
Old Feb 20, 2009 | 02:37 PM
  #175
mr2man07's Avatar
mr2man07
I am working on this right now, but came to a stopping point. Got the regulator and motor out no problem in about 15 minutes. But the problem is, my new regulator's wire spool came undone. Is there anyone that can help explain how to get it on or show pics of theirs on? The wires come in through a little x piece at two ends, and they go through a little valley before reaching the spool, then they connect and wrap around in opposite directions. It's a PITA!
Thanks,
Adam
Old Feb 20, 2009 | 03:56 PM
  #176
Cleanshots's Avatar
Cleanshots
hmm... my passenger one is not broken but it rulls up and down very slow when its cold... when its warm it works fine... i have cleaned and degreased the rail and still, same problem..
Old Mar 18, 2009 | 05:03 PM
  #177
Lady_D's Avatar
Lady_D
Thanks for the post! Very useful!
Old Mar 18, 2009 | 06:24 PM
  #178
Shmotz400's Avatar
Shmotz400
Originally Posted by no2faber
that's a great write-up OLT. i'm about to look into my friend's faulty power window on a Maxima. i automatically assumed that if the window doesn't go up it's the motor's fault (i'm sure the dealer replaces both just to jack up the price), but after reading this it seems everyone's problem is w/ the regulator rather than the motor. that's good b/c regulators cost about 40 shipped on ebay rather than 60+ with the motor for maximas in case i can't fix it w/ this write-up.
i work at a ford dealership and i pull 3 times as many regulators as i do motors for windows. things rarely break.
Old Apr 17, 2009 | 06:27 PM
  #179
GL123's Avatar
GL123
Easy Removal/Installation Procedure
I was having the same problem with the upper right guide bolt trying to remove the regulator and even more trouble with it when trying to re-install the regulator back in.
Here is the procedure that I used to re-install the regulator that worked well for me
- I noticed in your photo that you had removed the door trim upper panel which I did also. I also removed the window weatherstrip that is attached by metal clips.
- Raise the window all the way up and use a piece of duct tape to hold it up.
- Position the regulator so that the left upper guide bar bolt is through its mounting hole.
- You will need to apply pressure against the window to get enough space for the right upper guide bar bolt. The easiest way is to reach in from above where the weatherstrip was mounted and press against the window with your thumb while the rest of your fingers are pushing against the inside of the door. In the meantime use your other hand to move the guide bar so that the right upper bolt is threaded through. This was real easy once one created enough space.
It may be possible to avoid the extra steps of removing the door trim upper panel and the weather strip. One may be able to still apply enough pressure to create the space by sitting inside the car and pressing against the window with one's elbow while the door is closed. With the other hand one can then position the guide bar. I haven't tried this.
Old Apr 30, 2009 | 12:53 PM
  #180
mkesc400's Avatar
mkesc400
mine broke last week and i first fixed it with JB weld and it broke, so i tried it again but roughing it up more and it still didn't work, so then i tried panel bonding adhesive and it didn't work any better. any more suggestions?
