Window regulator fix for Sc models
Old Nov 1, 2007 | 05:48 PM
  #151
miraluna's Avatar
miraluna
myronl
I don't know where in cali you live, but if you would be in so. cali and if you would've gone to downtown Los Angeles, Alameda street, it would cost you less than 100 to fix it... there are about at least 50 shops on Alameda starting around 40th st to 110th st...
Old Nov 7, 2007 | 09:41 AM
  #152
myronl's Avatar
myronl
Default $100?
really? man. i was pretty desperate at that time. my driver's window had to be held up with clear packing tape... i finally reached the point that i just wanted it done. i sucked it up and brought it to the dealer... $475 out the window. however, i am up in the SF Bay Area. i actually asked around a few non-lexus shops and they gave me a similar price. at that point, i figured i should just goto the dealership.
Old Nov 24, 2007 | 11:13 PM
  #153
DiRocco's Avatar
DiRocco
Right in the middle of replacing my 1993 SC300 driver's side window regulator tonight! The guy that owned it before used a hose clamp around the regulator rail to hold the window up! LOL I did find that the plastic piece was pretty much destroyed with only one tab intact. The window guide rail was filthy too causing the window to stick anywhere I put it. A thorough cleaning followed by a teflon lube from Drummond should remedy that situation. I've found that it reduces friction even better than the silicon, at least on my other power window issues I've worked on over the years on my other cars. Thanks for the tips and hard work everyone!
Old Nov 25, 2007 | 08:53 AM
  #154
ChronoJ1's Avatar
ChronoJ1
Originally Posted by Luke_in_SD
Hey guys I don't know if I'm in same boat but some reason my driver side window has hard time going down at night or when its cool outside. Passenger is fine. i tryed to spray some silcone spray in the window tracks to see if it helps, cause it seems like its rubbing on something on the way down, but it made a minimal difference. There is no crackling noise, just a stubburn window.
Is this the regulator beginning to fail or something else?
I have the same problem. My passenger's side window works ok when hot and dry. But it moves slowly or barely at all when it's cold or wet.
Old Dec 23, 2007 | 03:13 AM
  #155
TheMole's Avatar
TheMole
Damn it, I'm pretty sure my regulator tab just broke as well as I heard a pop sound after I tried to roll up the driver's side window. I'll be getting one from Carson later this week.
I guess it is also a good time to replace the door handle snap connector while I'm in there.
Slow moving windows probably needs some lubrication or the motor is getting weak.
Old Dec 23, 2007 | 01:14 PM
  #156
Luke_in_SD's Avatar
Luke_in_SD
check the weather stripping on the outside where the window slides up and down. Occasionally the back part on the weather stripping on the door gets slides a little and slows the window when moving down. I just spray a little silicone lube and it slides freely again
Old Jan 22, 2008 | 10:58 AM
  #157
iant157's Avatar
iant157
Originally Posted by hotttoddie
So yeah... had the same thing happen to me... but i did as you said and JB Welded et al... Rewrapped the regulator put it all back together but within24 hours the damn thing breaks again! Tried once with JB Wink (the 4min set time) and then once with JBWeld (15hour set).... Both didnt work.... (I let both dry for 24 hours before reinstalling)
Any suggestions??
BTW - I have a Lexus OEM PDF doc that explains how to take apart the door and window to get to the regulator... YOU DO NOT HAVE TO BEND THE RAIL!!!! If you arent skilled enough to put it back youll always have that rough spot and itll make noise and put extra stress on the motor... Dont make the smae mistake I made and just go at it and f--- up your tint.... Do it right the first time... Itll take longer but its worth it.... Messgae me if you want a copy of the document...
please forward me the instuctions for removing the regulator properly. Thank you sir
Old Jan 22, 2008 | 07:09 PM
  #158
TooMuch92's Avatar
TooMuch92
Thanks man my driver side regulator just broke and i was gonna pay like a 100$ to get it fixed.
Old Jun 9, 2008 | 06:45 AM
  #159
charthu's Avatar
charthu
Default Regulator removal
I need some help in removing the window regulator. I have the door panel off and the screws removed. I can get the bottom out but I can not get the top to bolts out. Any help is greatly appreciated
Old Jun 9, 2008 | 07:13 AM
  #160
TheMole's Avatar
TheMole
Are you talking about the bolts holding the regulator to the door or the ones holding the glass to the regulator?
Try this link: https://www.clublexus.com/forums/sho...d.php?t=341373
Old Jun 9, 2008 | 08:53 AM
  #161
rwdanthony's Avatar
rwdanthony
i had my passenger window regulator die, but i replaced it. during the time i didnt see this thread.. i wished i did though, great thread!
Old Jun 10, 2008 | 09:18 AM
  #162
hotttoddie's Avatar
hotttoddie
In case anyone is still looking....
Heres that PDF...
http://www.gatorline.com/todd/1995SC300Door.pdf
Old Jan 9, 2009 | 01:25 PM
  #163
durtysc300's Avatar
durtysc300
do you have to take the window off to do this?
Old Jan 9, 2009 | 05:05 PM
  #164
hotttoddie's Avatar
hotttoddie
you dont take the window off... disconnect the window from regulator assembly...
Old Feb 7, 2009 | 01:02 PM
  #165
sorka's Avatar
sorka
My passenger window just did this a few days ago with 280K miles on the odometer.
Took about 10 minutes to remove the entire assembly. Not sure why so many are having troubles. 5 minutes to get the door panel off, 5 minutes for the rest(2 window bracket nuts, 3 rail nuts, 3 motor nuts, 3 screws holding cross brace).
Ordered it from Carson, but the price was $122. Couldn't find it cheaper anywhere else
