Over Drive dash light flashes?
Old Jul 22, 2003 | 10:04 AM
James1830's Avatar
James1830
Default Over Drive dash light flashes?
It only happens occasionally. The dash overdirve dash light just flashes randomly. The tranny shifts fine and stays in OD until the button is pressed. Any ideas?
Old Jul 22, 2003 | 10:31 AM
boredguy77's Avatar
boredguy77
short somewhere in the dash? loose connector on the shifter? just check all of the electrical connections.
Old Jul 22, 2003 | 11:02 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
The overdrive light flashes when the T. Convertor is slipping. Hopefully this is an easier fix for you than that.
Old Jul 22, 2003 | 02:12 PM
boredguy77's Avatar
boredguy77
I didn`t know that. But if the TC was slipping wouldn`t he notice some of the symptoms?
Old Jul 22, 2003 | 02:25 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
when it first starts to slip, the sensor re-acts. you might not notice it unless you "punch it" everywhere you go. even then, it may have just started and not be very noticeable.
like i said, there are a couple of things aside of this that will do it, but this is the built in safety sensor to keep you from burning everything up from the heat of slipping in the TC.
Hopefully it is something else. unless..... he has been waiting to go to a hi-output TC
Old Jul 22, 2003 | 02:37 PM
VVT-i's Avatar
VVT-i
It can be one of the shift solenoid goes bad too. Take it to shop and let them pull the code.
Old Jul 22, 2003 | 02:55 PM
2Lexus430s's Avatar
2Lexus430s
Could be evil Lepracons in your center consol messing with your wires!
Old Jul 22, 2003 | 02:58 PM
rushgator's Avatar
rushgator
Post
Are you off your medication again???
Old Jul 22, 2003 | 02:59 PM
2Lexus430s's Avatar
2Lexus430s
nope, its just that the ones I have now arn't as strong.
Old Jul 22, 2003 | 03:21 PM
rushgator's Avatar
rushgator
Post
Just as long as the voices that tell you to do things aren't as loud.
Old Jul 22, 2003 | 03:41 PM
2Lexus430s's Avatar
2Lexus430s
Does it only flash when you happen to be holding on to the shifter and pushing that strange little button in and out?
hehe, j/k
Old Jul 25, 2003 | 09:16 AM
James1830's Avatar
James1830
I like pushing strange little buttons.....
Just kidding.
I'll get the code pulled. There are no noticeable symptoms though.
Old Jul 25, 2003 | 10:55 AM
sweetsc400's Avatar
sweetsc400
I think you need to put your car in time out. Sounds like it's been a bad girl.
throw
Jan 8, 2016 05:03 PM
40cpe
Jan 1, 2015 08:49 AM
MIGS
Sep 24, 2014 02:32 PM
cm0nkey
Jan 6, 2008 07:11 AM
2Lexus430s
May 20, 2002 06:02 PM
