Another Tire Question (will my tires rub?)
Old Aug 11, 2009 | 09:38 PM
RocketGuy3's Avatar
RocketGuy3
Default Another Tire Question (will my tires rub?)
I tried a search, but I think this is a little too specific of a question (which might mean I can't get a good answer even with this thread, I'll see).
Anyways, I need to replace my rear tires very soon. I was looking at RE960AS Pole Positions, but they don't have the stock tire size of 255/40-18... or if they do, they're not listed at tirerack. I was thinking of going with 275/35-18, but I have aftermarket rims in with a +31 offset, and I'm lowered by about 1" in the back on Teins. So my question is if anyone has experience with a similar or even more aggressive set up. Do you think I'll have any rubbing issues?
Thanks a ton in advance.
... If you have any feedback on these tires, I wouldn't mind that, too.
Old Aug 12, 2009 | 06:32 AM
shadow191's Avatar
shadow191
With only a 9" width on an 18" rim, you should be ok even with a 275 tire.
I had 20x10"s with a +30 offset and it rubbed with a 275 tire. But that was a wider rim and a 20 so I had less clearance. With a 255 tire, I was fine.
Old Aug 12, 2009 | 08:42 AM
RocketGuy3's Avatar
RocketGuy3
Thanks for the reply, shadow. Was your car dropped at all when you put on those tires?
Old Aug 12, 2009 | 12:41 PM
RocketGuy3's Avatar
RocketGuy3
Anyone else?
I'm pretty worried about rubbing... I'm almost starting to consider 245/40-18 just to be on the safe side. I don't really want to downgrade, though. Damnit, why can't they have the right freaking size in stock.
Old Aug 13, 2009 | 06:52 AM
shadow191's Avatar
shadow191
My car was stock height with the 275's. Even with rolled fenders, it rubbed the letters off the tires. I swapped on 255/35's when I dropped the car on Tein's and rolled the fenders even more. It still rubs now, but it's not too bad. Keep in mind though that I had 20's and the larger diameter brings it closer to the body so it will hit more.
Old Aug 13, 2009 | 08:02 AM
SpecLexus's Avatar
SpecLexus
Alright, my 100th post. Gotta make this one count!
I've got the fsport springs drop with 265/30 rears with 19's and no rub. Looks good!
Old Aug 13, 2009 | 08:04 AM
shadow191's Avatar
shadow191
What is the offset on FSport wheels though?
Old Aug 13, 2009 | 05:46 PM
love67's Avatar
love67
im just clear on my rear with 275/30/19 with 9.5+37. i mean it is very very close to rub....btw, my rear has no gap.
Old Aug 13, 2009 | 11:46 PM
ijulmimi's Avatar
ijulmimi
F-sport wheels offset +40 both front and rear. 8" front 9" rear.
Old Aug 14, 2009 | 02:00 PM
RocketGuy3's Avatar
RocketGuy3
Did you lower your car at all?
Old Aug 14, 2009 | 02:44 PM
love67's Avatar
love67
i thought i said "i have no gap in the rear"....yes, i lowered with BC coilover.
Old Aug 14, 2009 | 02:51 PM
RocketGuy3's Avatar
RocketGuy3
I guess I misunderstood that comment... I mean that could theoretically mean that the bigger wheel/tire combo just filled out the gap (it's been so long that I don't even remember how big the factory gap was), but anyways, question answered.
So I guess you lowered it about the same amount as me then... probably about an inch? Sounds like I could have gotten that size afterall. Ah well, I chickened out and ordered Michelin Pilot Sport A/S Pluses just now since those are newer and had the size I needed.
Thanks for the help everyone.
SinisterIS
IS - 1st Gen (2001-2005)
Mar 1, 2012 12:51 AM
lahi671
Feb 3, 2012 09:14 PM
Vroomin350
Jan 28, 2011 02:47 PM
DKNY
Wheels, Tires & Brakes Forum
Feb 10, 2005 10:30 PM
