Battery repeatedly dies!!
Old Jul 25, 2013 | 02:21 PM
lever2000's Avatar
lever2000
Default Battery repeatedly dies!!
I have a 93 Sc400, love it. Except now it is acting up. The battery light came on just the other day sooo I believe Monday. Today is Thursday and I replaced the battery tuesday because the battery light came on and when I got home and came to a complete stop the battery light would come on and then I turned it off and it wouldn't turn back on. MY friend jumped it so then it worked. Later it came on again when I started driving. Alternator? I got that checked out and everything was fine. Ground wire? I checked that and all was fine there. I checked the alternator wire from the battery and there was some grease leaking onto the alternator. I assume leaking because there was grease on it. Then we just checked those two connections from the battery and on the way home.. the radio died out. I unplugged the deck and sat in the driveway. Reved a bit and then still it acted very weak. Turned on... did not turn on. Just put it on a trickle charger and it says the battery is completely dead. The battery was checked by Schucks and they said it was fine and a good battery. I bought it from motion auto supply. I do have 2 amplifiers hooked up but I disconnected the deck which disconnects the amps and still the light was on. Then I even took out the fuses just to be sure. Still nothing... I replaced the serpentine belt as well since the old one was a bit cracked and to be honest... I am desperate and may just rage sell if I can't figure it out. I don't want to take it to Lexus because they will overprice me just to tell me what the problem is. Thank you all!
Old Jul 25, 2013 | 03:02 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Just have the alt tested at an auto part store.
Old Jul 26, 2013 | 12:18 AM
lever2000's Avatar
lever2000
I did have it tested and it passed...
Old Jul 26, 2013 | 12:19 AM
lever2000's Avatar
lever2000
BAttery has ben on trickle charge literally all day and the 25% light just now came on.
Old Jul 26, 2013 | 10:15 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
If the shop diagnosed the alternator wrong, I'd suspect the diode packs on the alternator, but if they checked the diode pack specifically on the alt, I guess the logical answer is that you have a large drain somewhere, like wires crossed, or ground wires touching...
Old Jul 27, 2013 | 01:41 AM
RWDorGTFO's Avatar
RWDorGTFO
Have you tried a parasitic drain test?
Disconnect positive battery terminal side, measure the voltage from the terminal to the cable. If this reading is too high your battery is constantly being drained from a component, as touched on above.
Old Jul 27, 2013 | 01:57 AM
spacedog's Avatar
spacedog
Have your alternator tested at a shop that actually rebuilds alternators (they'll usually let you watch the test too). The tests done at places like autozone using a bench top computer or portable testing unit can often pass a failing unit...it's happened to me twice.
Old Jul 27, 2013 | 08:16 AM
2jznosht's Avatar
2jznosht
I'm thinking alternator too. Probably starting to go bad and killed the battery
Old Jul 27, 2013 | 10:49 AM
scENFORCER's Avatar
scENFORCER
You dont need to take it to Lexus. As mentioned before any alternator/battery shop will be able to diagnose it for you properly, not some kids.
After installing my carPC on my old '99 I had the same issue, some sort of paratitic drain that I could not locate, and testing the battery & alternator showed they were fine. Took it to my audio installer and he said there was no excess drain on the sysytem due to the carPC and no parasitic loss. I finally got fed up and just bought a new battery and a rebuilt alternator, had no issues after that.
As for the grease on the alternator, dont older 400's have the power steering resivoir located directly above the alternator? From what I remember it leaks onto the alternator and causes them to fail. You could look for that as well.
Old Jul 27, 2013 | 03:17 PM
1WILLY1's Avatar
1WILLY1
your power steering is leaking fluid on your alternator, you need a new alternator
same problem I had last summer
Old Jul 29, 2013 | 12:01 AM
lever2000's Avatar
lever2000
So what does it mean if the battery dies when the car is off?
Old Jul 30, 2013 | 06:23 PM
lever2000's Avatar
lever2000
Put a new alternator in it. Runs fine. But there was grease or PS fluid on it. Won't the same problem happen overtime?
Old Jul 30, 2013 | 06:27 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Yes. like ***** mentioned, your PS leaked onto your alternator which caused the failure most likely. You need to fix the leak or your existing alt will go bad.
Old Jul 30, 2013 | 08:05 PM
2jznosht's Avatar
2jznosht
Your alternator is also 20 years old. Just replace it and go from there
Mike234588
Sep 11, 2016 11:27 PM
gabzor
Mar 4, 2013 02:12 PM
masboy
Mar 4, 2012 06:37 AM
Donyo
29
Apr 4, 2011 11:54 AM
Cannonbear
Jun 17, 2005 05:03 PM
