No electrical power at all!
Old Jun 17, 2005 | 09:39 AM
Cannonbear's Avatar
Cannonbear
Default No electrical power at all!
anyone had this happen? i went to start my car this morning and nothing. works. the battery was changed this february, any ideas on what it could be?
Old Jun 17, 2005 | 09:42 AM
TLW's Avatar
TLW
possible light left on
jump the car and let it charge back up
if all it is is a dead battery
Old Jun 17, 2005 | 09:48 AM
sockfocks's Avatar
sockfocks
eh...if the battery is dead...you will need to put it on a battery charger overnight, if you dont you may end up with a defective battery and could push the alternator too hard and damage it. Reason being...the alternator is a trickle charger, it keeps the battery topped off, it wasnt designed to charge a fully discharged battery.
Old Jun 17, 2005 | 09:53 AM
Lexis11's Avatar
Lexis11
Check the positive terminal connection on the battery, if it is loose at all you wont have anything. It happened to me bro.
Old Jun 17, 2005 | 10:00 AM
markgs4's Avatar
markgs4
had it happen to me, but it was because a speaker wire was not grounded...shorted everything out. hopefully for you is something simplier like the battery....
Old Jun 17, 2005 | 10:18 AM
Cannonbear's Avatar
Cannonbear
well i tightened the positive cable (it was a little loose) and now the car starts up, but the RPM/speed gauges dont work. there's no light and the needles dont move. the radio,clock are fine just no dash instruments, is there a fuse?
Old Jun 17, 2005 | 11:53 AM
lexforlife's Avatar
lexforlife
just disconnect the neg cable for about 5mins then reconnect , your instrumentation will come back on , happened to me a few times when i was resetting ecu
Old Jun 17, 2005 | 12:02 PM
sockfocks's Avatar
sockfocks
man...these electrical "problems" are kinda scary...i was giving my truck a jump with my GS and VSC lights and some other lights came on i turned off the car and let it sit for a couple minutes and restarted it....lights went out... so...good luck man
Old Jun 17, 2005 | 12:20 PM
Cannonbear's Avatar
Cannonbear
You are my personal GOD! thank you!!!
All is well... for now.
Old Jun 17, 2005 | 12:50 PM
lexforlife's Avatar
lexforlife
we are all one family
Old Jun 17, 2005 | 04:27 PM
Canyonero's Avatar
Canyonero
I had this exact thing happen to me. It really freaked me out since I had just bought the car about a month ago and was thinking I might have a lemon on my hands ...but I just tightend the battery terminal and the problem was fixed.
Old Jun 17, 2005 | 05:03 PM
vicestan's Avatar
vicestan
Remove the clamps and use a knife to clear the connections, sometimes they have acidic build up that greatly restricts the flow of energy. The connectors are made of a very soft metal so just shave it untill you see clear metal, this should give you quicker start up and better over all electrical current.
Mike234588
Sep 11, 2016 11:27 PM
MoeSzyslak
Mar 10, 2014 02:28 PM
lever2000
Jul 30, 2013 08:05 PM
genijet
Sep 28, 2008 01:46 AM
ted920
Jul 31, 2006 10:17 AM
