do i need an alignment
Old Jan 8, 2003 | 02:33 AM
xBlkGs430x's Avatar
xBlkGs430x
Default do i need an alignment
im getting my springs 1.0" drop put on, will i need to get an alignment, will the dealer do it...
Old Jan 8, 2003 | 02:35 AM
AutoCoutureSC's Avatar
AutoCoutureSC
Post
hey ali,
yes you would need an alignment. the dealer can do it, but go find a place in your area that does alignments the old skool way... by hand. that's how i always do mine now...
Old Jan 8, 2003 | 02:55 AM
pcmw's Avatar
pcmw
I agree with do-luck. Those computers cheat the car back to stock settings and not adjusted for lowered cars. I had a computer alignment done on past cars and wore the tires incorrectly. I finally started taking my car to a place that does it the REAL way, by hand, and not a problem since. Tire wear is even.
MW
Old Jan 8, 2003 | 03:02 AM
howiedoit's Avatar
howiedoit
by hand? i never heard of that. what kind of places offer this kind of service? price?
Old Jan 8, 2003 | 03:12 AM
pcmw's Avatar
pcmw
I go to a local shop here in Sac.
They charge $80 for 4 wheel alignment
By hand means that they measure everything with manual tools that look like 6foot wide calipers to figure toe/camber/etc... then they use chalk while rolling the car forward and back to find the best contact patch with the road.
Basically a more purist method of testing the setup for altered suspensions.
I have found every local aftermarket parts shop refer everyone to the place and then found that my father took his cars there over 40 years ago.
MW
BTW.. Howie, with that 1.5" drop your car will not come back to perfect alignment. Some people may shim the crude out of it, but never to the point where you save your tires from premature wear.
Old Jan 8, 2003 | 03:13 AM
AutoCoutureSC
Post
there's a place in OC that can do it. whenever you're down give me a call. Yeah, it's pretty cool. Even if your car is SLAMMED to the ground with zero clearance, they can still work on your car.
what they have is like an underground pit they work in. just drive your car straight in like a parking spot, only they have a pit where they work under your car. I paid $70 for all four wheel alignment. Oh, they first test drive your car to see what the problem is.
Old Jan 8, 2003 | 04:54 AM
Grimpy's Avatar
Grimpy
Howie
You should try Bears wheels and allignment. It is across the street from McDonalds on Garvey. In between Del Mar and News.
Do-Luck
What is that shop you were referring to called? Bear said they couldn't adjust it all the way, they usually can on other Lexus's but not on mine for some reason. hopefully these guys could.
Old Jan 8, 2003 | 10:50 AM
xBlkGs430x's Avatar
xBlkGs430x
the shop thats going to put the shocks and springs will not do the alignment, will i be ok to drive on it for a couple of days...what could happen if i did not get a wheel alignment. becuase its going to be difficult to find someone to do it by hand.
Old Jan 8, 2003 | 01:47 PM
pcmw's Avatar
pcmw
Ali Hamed,
Everyday you drive it without an alignment, is more damage to the tires causing premature wear.
The car will be driveable thou, and the installer should not adversely effect the steering unless he screws up. Ask him before he starts if he has a supra/sc300 manual to know how to pull the front struts out.
MW
Old Jan 8, 2003 | 04:06 PM
AutoCoutureSC
Post
Originally posted by Sc4oo
Howie
Do-Luck
i have their card laying around here somewhere, but i asked them if they can align cars that are slammed. this is what he said
"i have done alignments all my life. I can align a car as close to factory spec as i can. I know a way that i can rig the arms for more camber without damaging anything."
so far so good. ALL my friends go there, from hondas to lexus to MBZ. like all shops say, it won't be factory spec, but they'll do it to the best they can. it took them about 1.5 hrs to do my alignment and that was with the eibach 1" drop.
Old Jan 8, 2003 | 07:56 PM
howiedoit's Avatar
howiedoit
hmm...i don't know if i have time to get it done in the sgv. anyone know of a good place in LA, preferably near westwood? the cheaper it is, the happier i am...as long as the work is done decently...
HAiS250
Suspension and Brakes
17
May 6, 2012 11:50 PM
RocketGuy3
Southwest
Aug 26, 2008 10:29 AM
aspguru
Mar 5, 2006 12:09 PM
Straight6
Mar 21, 2004 10:52 AM
Gs400TRD
Maintenance
Apr 7, 2002 02:12 PM
