Ground Wire Replacement
Old Apr 23, 2013 | 07:51 AM
AC1984's Avatar
AC1984
Default Ground Wire Replacement
Hey guys I have a question and please for give me if it sounds stupid. I have put together my own 4 gauge ground wiring kit. I want to know what do I do with the factory ground wires that are in the black electrical tape? Leave them hanging, cut them out or connect both the new kit to the old ground points. Please advise Please!!!!
Old Apr 23, 2013 | 10:27 AM
sj408's Avatar
sj408
What did you do? fabricate the kit to replace the stock grounds?
Its all up to how you "put together" your kit, I made a kit that went in addition to the stock grounds and has worked great thus far.
Old Apr 23, 2013 | 09:09 PM
AC1984's Avatar
AC1984
Please tell me exactly what you did. I have a 94 sc 300 after I wired mines up it started to act worst then before. The battery light did go out but then my electronics started to go hay wire. Radio went out and so did my head lights. Then car started running funny. I returned everything back to factory except the alternator wire. How do I add additional ground points correctly?
Old Apr 24, 2013 | 09:11 AM
sj408's Avatar
sj408
There are tons of additional grounding points you can use, Tell me exactly what YOU Did. why would you unhook all the stock grounds and such.... were you trying to completely replace them? if so youd have to make sure everything is properly grounded as stock and sounds like you didnt do that.
Use the search function there is info on this and exactly where to ground
Old Apr 25, 2013 | 08:54 AM
Dream36's Avatar
Dream36
I do this upgrade to most of the cars I own and definetly the ones I modified. IT is real easy to do so why not. I have a 2g wire running from battery to frame and another 2g from battery to motor. If I had another 2" of wire I woulda done another from motor to frame
mounting points are irrelevant as long as you sand paint for a good ground source.
Old Apr 25, 2013 | 12:29 PM
AC1984's Avatar
AC1984
SJ man... Ok what I did was unbolt and tape all of the factory ground points under my hood. ALT, Fire wall and the engine. Then I used the point to point connection method that I saw in a thread on CL.
This is the diagram I used but there are two things that I think caused my miss hap . First I own a 94 Sc 300 this digram is for a VVTI and secondly it does not elaborate on what exactly to do with the factory grounds. Thats why i just taped mines off. I know I just made a minor mistake but the QUESTION is WHERE?
Old Apr 28, 2013 | 10:39 PM
jjffyy's Avatar
jjffyy
I actually had sj408 make me some ground wires a while ago and they follow that same diagram. I left the factory ground wires bolted along with the new ones added on and it's been working great, not to mention I have a 95 sc300 so I don't think the VVTI matters.
Old Apr 29, 2013 | 08:39 AM
sj408's Avatar
sj408
Attachment 281260
the diagram is fine, you shouldnt have touched your stock grounds unless you were gonna replace them exactly how they were. this is to be installed in addition to the stock grounds, not as a replacement.
Old Apr 29, 2013 | 09:23 AM
AC1984's Avatar
AC1984
Thank you so much for that answr because I just couldn't figure it out. Over the weekend I just did the big 3 upgrade but i think I am going to try this mod again.
MIC123321
Apr 16, 2015 04:47 AM
LexISGS300
GS - 1st Gen (1993-1997)
Apr 15, 2012 07:43 PM
NemeGuero
Oct 20, 2011 10:14 AM
41
Jul 19, 2005 08:39 AM
sevens
SC400 / 300 Classifieds
Jun 17, 2005 03:14 AM
