Big3/Grounding Kit question
Old Oct 20, 2011 | 10:01 AM
NemeGuero's Avatar
NemeGuero
Default Big3/Grounding Kit question
So I started out just wanting to construct a grounding kit for my car but then since the big3 is one more damn cable I figured do them both in one shot.
Long story short, here are my questions:
1. Do I need to reconnect the OEM negative cable to the battery or can I completely remove/replace it with 2 cables going to the fender ground and firewall ground? (doesn't it tie in to the fuse box somewhere?)
2. I started off using 4gauge for my grounding kit but most people use 2 or 1/0 for big3. I have 1 amp that draws maybe 500W max. Will I need to go heavier gauge for my ground cables? Obviously for alternator positive I will use thicker.
Thanks.
Old Oct 20, 2011 | 10:09 AM
Mr Jokster's Avatar
Mr Jokster
4awg will be fine. As for the factory ground, no dont need to connect it, its just a small like 6inch wire to the fender. With the Big 3 you either add or replace whats already there, the more the better. As for the alternator wire, no need for 0awg, thats overkill with such a small set up.
Old Oct 20, 2011 | 10:14 AM
NemeGuero's Avatar
NemeGuero
Thanks, good sir.
AC1984
Apr 29, 2013 09:23 AM
LexISGS300
GS - 1st Gen (1993-1997)
Apr 15, 2012 07:43 PM
WildCanadi
Apr 11, 2010 11:45 PM
twizted
Jan 29, 2007 04:50 PM
Jmai22
Jul 11, 2006 07:10 AM
