Motor Swap
Old Jan 26, 2012 | 03:50 PM
Drifterkid's Avatar
Drifterkid
Exclamation Motor Swap
I have a 1993 sc300. My head gasket just blew the car has 199,000 miles on it and i was wonder if i should just swap the motor. Im gunna boost it so should i just go with the 2jzgte or 2jzge and boost it and if i do the gte is it a direct bolt n and plug in or do i have to swap ecu and stuff please let me know some options i got
Old Jan 26, 2012 | 05:12 PM
kinch09's Avatar
kinch09
I would go ahead and swap in a 2jzgte if you want to boost. but you can if you want go back to 2jzge or replace the HG and rebuild your motor, by that time you could have got a GTE
im no expert but its pretty much a direct "bolt" on. but plug and play not really i went ahead got my harness converted, i tried doing it myself and that was a NO GO! i ran into a lot of issues. get the harness conversion
with the ecu i used my 2jzGTE ecu. when you buy a swap most likly it will come with it. im pretty sure you can not use your 2jzge ecu
like i said im no expert but thought id let you know what i know, hope it helps good luck
Old Jan 26, 2012 | 06:04 PM
DuWerke's Avatar
DuWerke
Well there are a couple of variable you've failed to address.
What are your power goals?
What's your budget?
Need to answer those before you get into the whole "Swap or Not to Swap" topic.
Old Jan 26, 2012 | 07:21 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
My thoughts exactly.
Old Jan 27, 2012 | 01:37 AM
Drifterkid's Avatar
Drifterkid
Im looking to drift it so not alot of power but a good amount maybe 400- 500 but not right away im pretty much looking at what is the best way to go if im gunna spend the money
Old Jan 27, 2012 | 06:27 AM
DuWerke's Avatar
DuWerke
And what's your budget?
What's your timeframe to get all of this done.
Com'n man...gotta help us, help you here.
Old Jan 27, 2012 | 11:28 AM
Drifterkid's Avatar
Drifterkid
my budget really isnt a problem and time frame really isnt a problem
Old Jan 27, 2012 | 06:00 PM
DuWerke's Avatar
DuWerke
If that's the case for the 2JZ-GTE swap.
If money isn't a issue then go for broke.
Old Jan 28, 2012 | 12:32 AM
Cleanshots's Avatar
Cleanshots
1jz and 2jz prices went down.. at least here in calli there is a 1jz and a 2jzgte vvti about 30 mins from me one is 1300 and the 2jz is 2300.. if there is no budget then go 3.4 stroker engine from titan and go for full 1200hp.. lol
Old Jan 28, 2012 | 01:03 AM
mdmaniac's Avatar
mdmaniac
Hmmm.. So, you're rich and unemployed? Thought about making an NA drift car? There's a thread about it somewhere here but you'd have to put in a lot of work and probably $20k but it would be the meanest sounding drift car out there! I assume you already have the LSD?
If you go the GTE route, expect to shell out between $5k and $10k, depending on how much of it you do yourself. It's a drop-in motor (it's exactly the same as the GE but with different heads and intake, basically). Even once you've got the GTE engine and ECU (which you will need to make sure you have, because the fuel management is totally different,) to make the HP you're looking for, you're probably going to want to go single turbo. There are plenty of kits out there now for converting from twins to SBT (single big turbo). However, once you've done that, you should be looking at around 450-550HP.
If you went NA-T, you're talking Turbo Kit (2k up), injectors (another 1k-ish?) and ECU piggyback device to run the fuel management, plus a bit of heavy tuning. So... 5-10k vs 3-6k. Either way, you'll have fun.
Old Jan 28, 2012 | 11:14 AM
Cleanshots's Avatar
Cleanshots
5- 10 k for a gte swap? hell no thats stupid.. gte wiring will need to be made and converted to a rear sump most likely.. and when you do a gte you gotta change your tranny the stock 5spd will blow up.. so r154.. or if you go 6spd thats like 3k just for the tranny so yes if you did gte and a 6spd you would be in the 5-10k range.. if you are gonna do some serious drifting you are gonna need a full roll cage..
Old Jan 28, 2012 | 11:29 AM
DuWerke's Avatar
DuWerke
^^^ I dunno about the price range.
Just with the stock twins and auto tranny I paid 6K for my swap + labor.
MBH123
IS - 1st Gen (2001-2005)
Jun 5, 2016 09:23 AM
lequanus27
Sep 29, 2014 02:31 PM
SuicidnS13
Performance
Sep 25, 2011 03:52 PM
celiman05
Dec 9, 2006 10:01 AM
SCandilous
SC400 / 300 Classifieds
20
Jul 7, 2005 10:53 PM
