auto tt diff questions
Old Aug 25, 2011 | 06:56 PM
boosted516's Avatar
boosted516
Default auto tt diff questions
I found a guy selling a 97 tt auto diff locally, how can i make sure its lsd? He also told me he has a soarer 5 speed driveshaft, i plan on going 1jz so will these work together? Also do i use stock axles if i buy the diff? Thanks
Old Aug 25, 2011 | 07:12 PM
trancuongv's Avatar
trancuongv
Make sure it has the cooling fins on the diff itself. I'm not sure how you can tell without opening up the diff to check. Yes you would need a soarer front shaft if you wanted to mate this to a r154. You can use the back end of the 5 speed drive shaft. You can use the stock axles for the diff. R154 and auto TT pumpkin is a perfect combo. I have that combo myself with a 2jzgte single swap.
Old Aug 25, 2011 | 08:15 PM
boosted516's Avatar
boosted516
thanks for the info, do u know if the soarer driveshaft will bolt to the tt diff tho?
Old Sep 1, 2011 | 10:45 AM
broda805's Avatar
broda805
as long as its an auto i believe
Old Sep 1, 2011 | 01:08 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I think you can also use the front half of a mk3 driveshaft and the stock rear half of an SC driveshaft. may need to swap out flange on the diff itself also.
Old Sep 1, 2011 | 02:22 PM
99SC42's Avatar
99SC42
The cooling fins doesn't mean it's from a TT even Na SuPras have the cooling fins on the bottom of the diff....
Old Sep 1, 2011 | 08:10 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
If you have access to it, the foolproof way to tell is to take the cover off and see if it looks like an open or lsd. If you have cash in hand I dont think they would care if you want to take the cover off if its legit, cause if its an open diff then its pretty much worthless.
its a good idea to replace the seal on the cover anyways so it doesn't leak on you in the future.
Old Sep 5, 2011 | 08:11 PM
sc300bigtx's Avatar
sc300bigtx
i know for a fact that if your putting the auto tt pumpkin in a orginal 5 speed sc then you will have to change the flange on the diff not 100% about the auto sc's though
Old Sep 6, 2011 | 12:01 PM
broda805's Avatar
broda805
just installed one in my car just took it out and dropped right in
tt on the right stock 5sp on the left didnt have to do anything
opened it to make sure it had a torsen
Old Sep 6, 2011 | 10:03 PM
sc300bigtx's Avatar
sc300bigtx
ya i realized like 5 min after i posted this that when i bought mine it wasnt out of a sc so that would explain my situation
GS FONZy
May 3, 2014 07:18 PM
FuMoFFuTT
Apr 5, 2012 12:10 PM
BigGreen
May 29, 2009 08:08 AM
97-SC300
Apr 12, 2009 09:41 PM
DETUNED
May 31, 2004 07:06 PM
