Cv axles???
Old Aug 31, 2011 | 10:05 PM
millertime's Avatar
millertime
Thumbs down Cv axles???
So ya 370hp + welded 429 diff = rattling cv shafts
is there any difference between sc300 axles and supra axles
i know that the mr2, celica alltrac, v6 camry all used the same half shafts
I would like to find a better version half shaft, thats not gonna be $900
i can get sc300 half shafts for like $60.
is it an advantage to get supra ones or are they the same?
Old Aug 31, 2011 | 10:18 PM
k7q's Avatar
k7q
maybe the axle were old and worn out? get another set of oem axles and get them rebuilt so its has new ball bearings and packed with grease. oem axle can handle 370hp
Old Aug 31, 2011 | 10:20 PM
lex92sc300's Avatar
lex92sc300
on auto same on six speed rearend left side has to be changed and think they are slightly larger diameter i think some one jump in correct me if im wrong..
Old Aug 31, 2011 | 10:29 PM
millertime's Avatar
millertime
they are exactly the same, and yes the passanger side has no grease in it
i think ill go with oem unless some one has some crazy idea
Old Aug 31, 2011 | 10:43 PM
lex92sc300's Avatar
lex92sc300
i know with the six speed the shaft on driver side is longer why you have to have the six seed shaft if you replace your rear with the six speed rear end
Old Sep 6, 2011 | 11:05 PM
93twintrbo's Avatar
93twintrbo
TT auto axles have a larger shaft diameter by about 5mm. Stock oem SC axles will handle over 500whp all day. TT auto axles will handle proven 900+whp with ease.
Lawrence
angus
Performance
Jul 14, 2014 07:29 PM
dkekim01
GS - 1st Gen (1993-1997)
Jun 11, 2013 02:03 PM
bobmarley
Nov 29, 2007 04:06 AM
