Cat delete question
Old May 29, 2011 | 10:27 AM
Launch1's Avatar
Launch1
Default Cat delete question
Will deleting the 2 cats before the o2's on these cars throw a code?
Old May 29, 2011 | 09:14 PM
6SOARER's Avatar
6SOARER
It depends if your SC is OBD1 or OBD2. OBD2 expect to get a CEL for deleted cats, if your pre OBD2(95 and older) you should be OK.
Old May 29, 2011 | 10:15 PM
JDMmuscle's Avatar
JDMmuscle
CL Folding 200,000
This has been covered MANY many times.
Here I searched for "Cat Delete" in the SC section
https://www.clublexus.com/forums/sc-...ght=Cat+Delete
I even narrowed it down more for you...
Here I searched for "Cat Delete check engine light"
https://www.clublexus.com/forums/per...k+engine+light
Here is "Cat Delete Problems"
https://www.clublexus.com/forums/per...elete+problems
Last edited by DaveGS4; May 30, 2011 at 03:30 PM. Reason: fixed links - search links only work for the poster, not other members
Old May 30, 2011 | 03:04 AM
1UZAristo's Avatar
1UZAristo
Mmmm as above ^
Old May 30, 2011 | 06:32 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
https://www.clublexus.com/forums/sea...archid=6655094
https://www.clublexus.com/forums/sea...archid=6655091
https://www.clublexus.com/forums/sea...archid=6655098
Great answer (edit - fixed your links in post above)
OP (Launch), PLEASE try searching first before posting questions. 99% of the time you can find an instant answer, no waiting.
Old May 30, 2011 | 08:00 AM
RockRash's Avatar
RockRash
haha i opened each of those links there's nothing there ? Sorry - no matches. Please try some different terms. so much for search
Old May 31, 2011 | 08:19 AM
JDMmuscle's Avatar
JDMmuscle
CL Folding 200,000
Thats odd, they work for me
Old May 31, 2011 | 08:27 AM
DaveGS4's Avatar
DaveGS4
Should work for other folks too now, I fixed them . When you post the search link that works for you because you have the cookie on your PC storing the search criteria, so you can re-execute the search later. Other folks don't have that cookie, so it doesn't link to anything. Got to post the actual search results, which I guessed at and edited / pasted into your post
DVL5WRK95
May 21, 2019 04:47 PM
GTR20
Performance
May 18, 2019 08:08 PM
Lveyolfe
Apr 18, 2017 05:04 PM
LexusISF19
IS F (2008-2014)
Apr 24, 2014 06:48 PM
