Vibration During Braking
Old Dec 22, 2010 | 12:10 PM
Lexus082's Avatar
Lexus082
Default Vibration During Braking
I have a 94 Sc400 and when I apply the brakes I get a shimmy pulsating type of vibration which can be felt through the brake pedal. Which tells me its coming from the rear brakes and not the front. I thought it was the rear rotors possibly being warped and causing the vibration. So I replaced the rotors and there was no change. All suspension bolts are torqued to spec. The brake pads are wearing evenly, so I dont see any problems with the caliper. Any suggestions as to what may be causing this.
Old Dec 22, 2010 | 01:13 PM
johnboyjh's Avatar
johnboyjh
Default shimmy
Chk runout on ft. rotors.
Old Dec 22, 2010 | 01:40 PM
SChema's Avatar
SChema
Fronts can cause the pulsation to come through the pedal as well. If you feel the pulsation in the seats or feel and back and forth motion of your head then usually its from the rears.
Old Dec 22, 2010 | 02:06 PM
Lexus082's Avatar
Lexus082
I'm 99% sure its coming from the rear. Often with a problem with the front rotors you can feel the pulsating through the steering wheel. The entire rear end shakes upon medium pressure on the brake pedal. Light pressure don't notice hardly any vibration and if I slam on the brakes theres no vibration/pulsating...
Old Dec 23, 2010 | 02:36 PM
1980's Avatar
1980
Wheel bearins have the same effect as bad rotors might check those to.
Old Dec 23, 2010 | 08:37 PM
sc3tech's Avatar
sc3tech
yeah usually if the pulsation is felt at the steering wheel its from the front wheels. If you dont know where the pulsation is coming from then its usually the rears
Old Dec 24, 2010 | 07:28 PM
Lexus082's Avatar
Lexus082
Its not the wheel bearings, they have been replaced and are new.
Old Dec 24, 2010 | 11:27 PM
lfrers's Avatar
lfrers
A great majority of breaking comes from the front. Every single time I have ever felt pulsating during breaking in any vehicle I have owned it's always turned out to be the front rotors. You can turn them but they are so cheap just buy new ones.
Old Dec 27, 2010 | 12:53 PM
joliroger4's Avatar
joliroger4
Check the caliper bolts with the bushing that goes on the end. Duralast makes replacement bolts and bushings. If they are bad or broken off, you should be able to feel the looseness in the calipers when you grab them and try to jostle them. Floating caliper systems suck when they get old. Fixed calipers with many pistons are so much better.
JDMis350
Oct 7, 2012 12:54 PM
shajbot
Sep 21, 2011 08:09 AM
danxp
May 28, 2011 07:47 AM
gmendoza
Suspension and Brakes
Apr 20, 2004 12:56 AM
ralphwiggums
Aug 25, 2003 11:46 PM
