Eibach problem
Old Nov 22, 2010 | 11:23 AM
leonsup's Avatar
leonsup
Default Eibach problem
Just had 8230.140 Eibachs installed on my SC300. Are the springs the same for the SC3 & 4? Having some problems.
Old Nov 22, 2010 | 11:37 AM
turbodremz's Avatar
turbodremz
They should be identical...what problems are you having?
Old Nov 22, 2010 | 12:04 PM
leonsup's Avatar
leonsup
Rears are coil on top of coil....no daylight between them.
Old Nov 22, 2010 | 01:59 PM
ashtray's Avatar
ashtray
That sounds like a serious defect in the product.
Old Nov 22, 2010 | 02:23 PM
turbodremz's Avatar
turbodremz
Check the spring number, it should be 8230.14X...if it isnt, contact the buyer who sold them to you. Do they sit on the perch properly? Any way to get pictures of them?
Old Nov 22, 2010 | 02:28 PM
leonsup's Avatar
leonsup
OK, I just got back from driving it.........bangs when hits a bump but only on the passenger side & he had replaced the upper mount. He said he checked everything & thinks the springs are wrong. I'm not so sure. Struts? Sway-bar links? Any ideas?
Old Nov 22, 2010 | 02:50 PM
turbodremz's Avatar
turbodremz
Blown shocks wont cause the spring to seat coil-on-coil, neither will s/b links. Only thing I can think of is they are the wrong springs, or factory defect..which again, is highly unlikely. Raise the car up, and check the number on the spring. Thats the only advice I can give right now. Where did you get the springs from? New or used?
Old Nov 22, 2010 | 03:21 PM
leonsup's Avatar
leonsup
Tirerack....there ARE gaps, but only possibly 1/8", then the last couple of coils spread out more....that's why I'm thinking the springs might be OK...
Orozco27
Suspension and Brakes
May 1, 2014 09:04 AM
Mike552
May 6, 2012 03:27 PM
enigma65
Feb 12, 2012 07:03 PM
young's 96
Jun 13, 2009 06:31 PM
