lowering my car
Old Jun 10, 2009 | 11:58 AM
young's 96's Avatar
young's 96
Default lowering my car
I wanted to know if I cut my springs to lower my car how will it still ride, will it be bouncy like when you heat your springs?
Old Jun 10, 2009 | 12:28 PM
GS300ToM's Avatar
GS300ToM
my question is WHY?? buy springs dont cut plzz haha
Old Jun 10, 2009 | 12:31 PM
Sheehan1p's Avatar
Sheehan1p
★ I
Noooo dont cut your springs I was in the same situation as you heres a link https://www.clublexus.com/forums/gs-...-your-car.html
Old Jun 10, 2009 | 02:46 PM
V8RdnLow's Avatar
V8RdnLow
x2
You can find some used springs in the classified section. GL
Old Jun 10, 2009 | 03:09 PM
SoCal Cyco's Avatar
SoCal Cyco
yes it will be bouncy and you risk blowing out your shocks right away. don't do it. buy used shocks if you want a cheap fix
Old Jun 10, 2009 | 03:15 PM
PushinLEX's Avatar
PushinLEX
please don't. get coils, air, or aftermarket springs/aftermarket struts. you'll end up payin more in labor and repairs in the long run.
Old Jun 10, 2009 | 03:21 PM
denut-L's Avatar
denut-L
I had stock struts on cut sprint springs slammed to the ground and it's bouncy and looks great, but when you hit a bump it feels like one of your wheels came off
Old Jun 10, 2009 | 05:21 PM
ZippyGuy's Avatar
ZippyGuy
I'm amazed that someone is actually cutting springs and would deal with a bouncy ride on a Lexus
Old Jun 10, 2009 | 05:54 PM
4ntvings's Avatar
4ntvings
(waiting for 4play4dr to chime in)...........lol
just get a set of used springs
Old Jun 10, 2009 | 06:33 PM
5t341th's Avatar
5t341th
damn dont cheap out on your lexus. this aint the honda days
Old Jun 10, 2009 | 06:42 PM
timgs300's Avatar
timgs300
You are already doing all the work to remove the spring if you are going to cut it. Why not buy some used springs to be cost effective and not risk cutting the spring may be unsafe.
Old Jun 10, 2009 | 06:57 PM
PushinLEX's Avatar
PushinLEX
we seriously need a sticky about proper lowering. i'm seeing a handful of similar posts weekly.
Old Jun 10, 2009 | 08:28 PM
kingkirby's Avatar
kingkirby
just try it. if u like it keep it. if u dont...buy legit springs.
Old Jun 10, 2009 | 09:37 PM
GCOP's Avatar
GCOP
CL Folding 100,000
Cutting the springs isn't too bad, it really depends on how low you want to go, if it' smore than about an inch or so, you won't be happy, and the ride will suffer, also keep in m ind, you will have to cut the bump stops as well, i fyou don't want that harsh slam, every time you hit a bump.
....as mentioned, you can't argue with the labor side of it, it's actually MORE work to remove, cut and properly reseat the springs, vs. just slapping in some new ones. But sone properly, it isn't horrible. I would say those who run into problems, are trying to go yoo low with it thus bouncy ride, blown shocks etc. It can be done correctly, and be OK, but it is time consuming and it does have it's limits.
Old Jun 10, 2009 | 11:54 PM
PushinLEX's Avatar
PushinLEX
But this defeats the purpose of lowering. The 2GS wheel gap needs way more than a one inch drop. Your really wasting your time, and time is money, to bother with cutting an inch, then having to redo the whole thing later again because either its not enough drop, is killing your ride quality, or worse.
There are certain categories of mods to your car than you "maybe" can cut corners with "if you must", but suspension is definitely not one of them, especially with a Lexus. Your buddies and females will sit in your car and be like, "wtf, are your struts blown?" it really kills it.
the way i see it, if you have to resort to cutting springs, you don't have enough money to drop your car properly. thats that. just save some money and ride at stock high longer or find a good deal that is going in the right direction towards a proper drop.
i really dunno what else to say, but in the end, its your car, we're just warning you and trying to give u reasonable notice as to the foreseeable results of doing this.
i've seen it before, and unfortunately, i'm sure CL will see it again.
