Search button is obsolete. Another camber thread.
Okay, I can't find a straight answer. Apparently the Diazen camber correction kit has been on back order forever and I have found this on Titanmotorsports.com: http://www.titanmotorsports.com/r2rabcacokit.html looks just like the Diazen bolts and bushings (camber correction kit) and I also found this http://www.titanmotorsports.com/hocaplkitred.html
So which one do I have to/should get to fix THIS? *Note* I only need it for the front.
When I went to get an alignment they said they tried to make it straight as possible. I'm on Megan coilovers but the description of the plates didn't specify if it was only for Hotchkis products and I never dealt with buying camber plates separately so I don't know if it would work or not
Okay, I narrowed it down to these 2 options. Which one will do the best job?
This: http://www.titanmotorsports.com/r2rabcacokit.html
OR THIS: http://cgi.ebay.com/ws/eBayISAPI.dll...skI7gOO0w%253D
need help noooowww
need help noooowww
I honestly think you could get your camber to be ALOT better just simply using stock materials.
Its bolts with adjusters on the lower control arms, try it before spending a few hundred dollars
HUH??????????????????? should be able to adjust it stock andget most of that out. looks like they added more negative camber. NOTE: pull the LCA in tward the exhaust not out tward tire with the eccentric bolt. help?
looks like your car has a pretty big drop. If you have already maxed out the positive camber on the stock adjustments, your only option is to get a camber kit or the adjustable upper arms. The camber kit you found for the supra would work, but unfortunately R2 racing also have had their camber kits on back order as long as daizens, so you wont be able to get the kits from titan or mvp. The upper arms would work, but they are also inferior products made in china, I would not run the risk of running them. How low are you anyway?
