megan camber kit
Old Nov 9, 2011 | 09:58 AM
monet33's Avatar
monet33
Default megan camber kit
I wanted to get the camber arm and the toe kit to eliminate tire/camber wear. I wanted to get the camber arm(pic one) but they also have camber kit(pic two). Which one is needed cause I see two different ones. Thanks
Old Nov 23, 2011 | 08:12 PM
joedad's Avatar
joedad
Depending on how much you take out of the neg. camber you may not need the toe kit because the factory adjuster be able to compensate. Check with Lexus alignment guy and discuss how far you can go before you need the toe kit. You might be pleasently surprised. I'm doing my front at about -0.2 with a 0.05 total toe and the rear at -0.2 and toe as close to 0.00 as possible. A toe of 0.05 works fine from what my Lexus guy says. Zeroing out the camber will cause the tires to roll on cornering so some neg. is necessary. I already have the front camber kit but not the rear yet so I'm gunna take the rear tire off and see what the top arm looks like, I believe that it is the first pic.
Old Nov 24, 2011 | 11:35 AM
monet33's Avatar
monet33
thanks for the info joedad
Old Nov 24, 2011 | 12:46 PM
Sffd103's Avatar
Sffd103
Fire Slayer
I have the first ones on the left to add or remove camber.
Old Jan 4, 2013 | 01:31 PM
Woowee's Avatar
Woowee
What does the second one do?! Anyone? Haha. Thanks in advance
Old Jan 4, 2013 | 01:51 PM
whitebeast's Avatar
whitebeast
The second arm use to adjust the toe (car go straight not pull to a side). Top arm to adjust camber of the wheel
Old Jan 4, 2013 | 09:37 PM
ThreeFive0's Avatar
ThreeFive0
You shouldnt need the right pic. The stock Lexus arms that the second pic would replace are adjustable enough. Just buy the left pic in order to adjust the camber. If I am wrong then I will let you know in a few days when I go to get my alignment done. I just lowered with BC coils and the left pic camber arms.
Old Jan 4, 2013 | 09:46 PM
Sffd103's Avatar
Sffd103
Fire Slayer
toe is what KILLS tires!
darinmg
Suspension
Mar 22, 2014 02:41 PM
sleekbrian
Suspension and Brakes
Aug 3, 2012 12:34 PM
pwrusr
Suspension
Jul 30, 2012 06:40 AM
VIS250P
22
Jan 8, 2012 05:38 PM
bacon22
IS - 1st Gen (2001-2005)
Jun 15, 2011 05:51 AM
