'99 SC400, whats leaking?
Old May 11, 2009 | 07:31 PM
Durrby's Avatar
Durrby
Default '99 SC400, whats leaking?
Two small spots on the driveway about 1 & 1/2ft apart. I know nothing about the 1UZ.
Old May 11, 2009 | 07:36 PM
slappy96's Avatar
slappy96
High pressure power steering hose. Good bet.
Old May 11, 2009 | 07:43 PM
Durrby's Avatar
Durrby
thanks for the fast reply. if so is that a cheap problem to fix?
Old May 11, 2009 | 07:47 PM
StiCk3's Avatar
StiCk3
^^it is if you find a repair shop that specializes in hydraulics. Do a search on "power steering line repair" and it'll give you info on what to look for. It's mostly for SC300 though, but the repair can probably be applied to the SC400 line as well.
the second option is to pay far out the *** for a new one from the dealer. $400ish new.
Old May 11, 2009 | 08:02 PM
Durrby's Avatar
Durrby
Originally Posted by StiCk3
$400ish new.
damn...not the answer i wanted to hear
i'll call a few shops in the area by this weekend..how imperative is it to get it fixed?
Old May 11, 2009 | 09:41 PM
RedPhoenix's Avatar
RedPhoenix
Go to a hydraulic shop and bring them the hose. they can replicate it with better parts for $50 or so.
Old May 16, 2009 | 09:37 AM
Durrby's Avatar
Durrby
well i'm bummed out...took it to a shop to get it looked at and had them do a "used car check." came back with this...
High Side Power Steering Hose From Pump-$614.81
Power Steering Pump-$454.14 + Tax
Power Steering Rack-$1368
Valve Cover Gasket-$244 + Tax
High Side AC Hose From Compressor-$231.94
Nothing has been done yet. This is parts + labor.
Old May 16, 2009 | 10:38 AM
StiCk3's Avatar
StiCk3
THAT's a little overkill for a leaking PS line. Yikes...
Old May 16, 2009 | 12:10 PM
Eclipsor00's Avatar
Eclipsor00
Holy god, ya gotta be retarded to pay those prices. Do it yourself. Christ 244 even for the valve cover gasket...lol 30 bucks for the gasket.
Old May 17, 2009 | 03:10 AM
sc-driver's Avatar
sc-driver
Hold up! Is the oil filter right above that? Looks like it in the pictures.
Check to make sure that's on tight.
I know when you get the oil changed, you can accidentally leave the old o-ring on and place the new filter with the new o-ring over it. It could leak through that and then onto those hoses. Check that out too.
Old May 17, 2009 | 10:16 AM
ScottURnot's Avatar
ScottURnot
From: Sideways on the Yellow Brick Road! < Thats KS!
If I were betting I would say just the pump is leaking and dripping on the lines. If those lines leak its much more than a drip. Most common leak for the SC400 is the PS pump. They start leaking at 80,000 to 100,000 miles.
Old May 17, 2009 | 10:33 AM
Durrby's Avatar
Durrby
tell me about it
i'm not even sure thats leaking. if it were to be leaking would it drip to the ground? cause the only thing I see is the slight ps leak.
it is but there's a spot on the other side too. i'll check it out
wouldn't surprise me. they may be right about the rack though. i noticed the inside of my front wheels appeared to be wet or got wet and dried. didn't look like water. i'm gonna bring it to another shop and have them also do a used car check and see what they find. car is at 130k though.
Old May 17, 2009 | 02:55 PM
Anthony85's Avatar
Anthony85
That shop gave you the bend over fees!
O. L. T.
Mar 6, 2006 06:54 AM
CompuMan
Maintenance
May 2, 2005 01:38 PM
VQT
Aug 28, 2001 06:44 AM
