climate controle problem...
Old Sep 4, 2008 | 08:58 PM
teamavr's Avatar
teamavr
Default climate controle problem...
for some reason when i was done instailing a new deck on my 92 sc the climate controle didnt work but it worked befor i did the instail....... when i got the car the wire's was very messy because of the deck that the last owner did so i had to do alot of wire testing and stuff....but everything works. but the climate controle? i have a feeling i fryed somthing or shorted somthing out.. the climate controle light turns on but no light on switch and nothing shows on the screen and nothing works the only thing on the climate controle that works is the yello light in the lcd screen. HELP PLEASE SO I CAN FIX THIS PROBLEM LITTLE THINGS LIKE THIS IS HEADACE! =/
Old Sep 4, 2008 | 09:30 PM
teamavr's Avatar
teamavr
Help??? Please
Old Sep 19, 2008 | 09:18 AM
zegnaguy's Avatar
zegnaguy
I have the same exact problem right now. Anybody have more info?
Old Sep 19, 2008 | 08:37 PM
xxtoobsxx's Avatar
xxtoobsxx
OMg...lol...i have the same friggin issue right now. I even bought a new working climate control and nothing. I am about to see if replacing the harness will work!
Old Sep 19, 2008 | 09:56 PM
zegnaguy's Avatar
zegnaguy
I checked my fuse tonight and sure enough it was blown. New one fixed it all up. Lucked out.
Old Sep 22, 2008 | 09:18 AM
xxtoobsxx's Avatar
xxtoobsxx
Which fuse and where? Kick panel or under hood? Im 6'4" So it is a pain in the *** to check those, let alone see and pull the right one
Old Sep 22, 2008 | 09:23 AM
zegnaguy's Avatar
zegnaguy
inside kick panel. think it was the only 25amp fuse I had in there. Not sure if that was factory 25amp or if I previously put it in there. It wasn't the bottom row and it was 2 or 3rd from the right hand side of kick panel.
Old Sep 28, 2008 | 09:22 PM
xxtoobsxx's Avatar
xxtoobsxx
So i checked all fuses and mine are all good. However I still have no climate control functions. It lights up but thats about it...any other ideas?
Old Sep 29, 2008 | 02:23 PM
P Weezy's Avatar
P Weezy
SAME PROBLEM AS ME!!! can someone pleaseee come up with a solutionn, i need to know some answers too
Old Sep 30, 2008 | 09:57 PM
xxtoobsxx's Avatar
xxtoobsxx
I guess we are the only two people who this has happened to P WEEZY
Old Sep 30, 2008 | 10:07 PM
P Weezy's Avatar
P Weezy
maaan, i guess so huh lol
Old Mar 2, 2009 | 08:44 AM
TheRonTom3's Avatar
TheRonTom3
I have this same issue as well. Still no answer to this. All lights on climate control work but no functions and no read out on LCD screen.
Any help?
Old Mar 2, 2009 | 08:58 AM
JPSFAB's Avatar
JPSFAB
have you guys checked all 3 plugs from the back of the climate control?
Old Mar 2, 2009 | 09:11 AM
xxtoobsxx's Avatar
xxtoobsxx
I fixed mine, i didnt know the cig fuse was connected to it also. Yet it kept blowing, then i remembered when i bought the car the cig lighter didnt work. Since i dont smoke i unplugged it again and have never had a climate control problem since. I even bought a new climate control thinking my unit was bad! HAHA
Old Mar 2, 2009 | 10:32 AM
durtysc300's Avatar
durtysc300
I had a similar problem..it did the same as what you guys described, i checked the fuses under the kick panel and my cig lighter was blown, so i replaced it, now it only stays at 75 degrees, and doesn't even blow cold anymore..ugh
