alignment maxed out?
Old Oct 10, 2011 | 06:59 AM
jjffyy's Avatar
jjffyy
Default alignment maxed out?
Changed my LCA bushings yesterday and got an alignment. The mechanic said that the camber is maxed at -3.4 degrees all round. This sounds awfully negative considering I'm not slammed. Currently dropped on tokico and eseplirs. I knew I would run some negative camber but this seems a bit high for my drop.
Old Oct 10, 2011 | 07:07 AM
TechGreek's Avatar
TechGreek
Either something is bent or your mechanic doesn't understand how to align a car.
Old Oct 10, 2011 | 07:12 AM
Tabaka's Avatar
Tabaka
x2, I'm running the EXACT same set up with Espiler and Tokicos and have negative 2.5 in the rear and like 1.8 in the front. I have 19" x 9"s + 15 up front and 19" x 10"s +15 out back.
Old Oct 10, 2011 | 07:24 AM
jjffyy's Avatar
jjffyy
Yeah I think its just the mechanic. I took it to tirekingdom because I had a free 1 year alignment with them after purchasing some tires a couple months ago. I think I'm gonna find another shop.
Old Oct 10, 2011 | 03:34 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
It takes a while to find the right place but I eventually found a shop wiling to do the lance alignment and they nailed it.
Im not as low though I am on tanabes, but the car handles much better now with these specs.
Its def the mechanic or something is way off.
http://www.mkiv.com/techarticles/lan...ent/index.html
Old Oct 10, 2011 | 03:50 PM
ArodDaLob's Avatar
ArodDaLob
It's not hard to figure out if your alignment's maxed out.
Get under the car and look at the rear subframe from the back and there are 2 bolt heads w/ dials on them at the bottom corners of the subframe. If the dials are pointing towards the outside of the car, then the camber is physically maxed out.
Another thing is some shops will say "it's maxed out" b/c of the toe correction limitations, so I would check the eccentric bolt that holds the toe rod onto the subframe if the lca bolt isnt' maxed out.
JM51526
IS F (2008-2014)
Jun 30, 2014 09:16 AM
6gs430
Feb 27, 2013 05:54 PM
OG Dada
Oct 2, 2011 10:51 AM
xx69xx
Jul 21, 2008 12:52 PM
redgs4
Suspension and Brakes
Jul 10, 2002 11:31 PM
