Door Alignment
The difference came after changing the door hinge on the drivers side.
Does somebody knows how the pins on the body side can be removed in order to move the hinge back and forth?
I guess I can use some washers as spacers on the door side of the hinge but the passenger side does not have any shims.
I will appreciate any help on this matter.
FRONT DOOR ADJUSTMENT
1. ADJUST DOOR IN FORWARD/REARWARD AND VERTICAL DIRECTIONS Loosen the body side hinge bolts to adjust the door panel. HINT: Remove the pin on the body side before performing adjustment and reinstall it when finished.
2. ADJUST DOOR IN LEFT/RIGHT AND VERTICAL DIRECTIONS Loosen the door side hinge bolts to adjust.
3. ADJUST DOOR LOCK STRIKER
(a) Check that the door fit and door lock linkages are adjusted correctly.
(b) Using a screwdriver, remove the striker cover.
HINT: Tape the screwdriver tip before use.
(c) Adjust the striker position by slightly loosening the striker mounting screws, and hitting the striker with a hammer. Tighten the striker mounting screws again.
(d) Install the striker cover.
It started happening again a week or so ago (might be the cold spell we just had??) and I'm in the mood for fixing it myself.
From what I can see, it's completely an alignment issue. I know that the intent behind the 4-link hinge assy. is to not only swing the door out, but away from the driver upon exiting the vehicle. On my car, what I see is that the door doesn't swing away as much as it needs to be able to clear the fender panel. Thanks to sc300max for the diagrams. I just printed them and am going to tinker in the garage for a while.
Also, for anyone else reading, these helped me understand some root causes of them problem (save you the searching):
https://www.clublexus.com/forums/sho...door+alignment
My goodness I want this problem fixed. Every time I hear that crack sound I want to snap it's so bad. It's to the point where the fender panel actually flexes until the door lets it loose and pops out....
