Brake Clearance
Old Mar 1, 2006 | 05:52 PM
$C300's Avatar
$C300
Default Brake Clearance
Well guys I have been searching and couldn’t get an exact answer, I want to upgrade to TT breaks but I only have about .5in of clearance between my front calipers and the rims and and about 2in from the rotor to the rim, they get tighter as you move toward the edge of the rims.
Can I fit the TT brakes or even the LS ones?
Heres a pic.
Old Mar 2, 2006 | 05:15 PM
$C300's Avatar
$C300
Any one ?
Old Mar 2, 2006 | 05:20 PM
AME_VIP's Avatar
AME_VIP
I don't know what you mean by rotor to rim but I doubt LS or TT brake would fit.
For Supra TT you need about 45mm of clearance front the rotor hat the spoke of the wheel. Keep in mind Supra TT has 13" rotors so measure at about 6.5" from the center of the rim face.
Old Mar 2, 2006 | 05:37 PM
$C300's Avatar
$C300
by rotor to rim i ment the face of the rotor to the baq fo the spoke on the rims, anyway that not good new i guess im going to hold off on the upgrade and just get new rotors and pads.
Old Mar 2, 2006 | 05:49 PM
bruce van's Avatar
bruce van
I don't think you'll be able to even come close to clearing LS brake calipers with 2 inches.
I had 2.5 inches of clearance before upgrading and I barely had enough clearance.
I was in the same boat as you and wasn't sure, but I took the plunge and it worked out fine.
My pix here CLICK TO THREAD
Old Mar 2, 2006 | 06:13 PM
$C300's Avatar
$C300
i guess ill save the $$ for sum new MUCH lighter rims.
Old Mar 3, 2006 | 12:33 AM
Chawk60's Avatar
Chawk60
Don't know if this will help but I found this on a search...
https://www.clublexus.com/forums/sho...d.php?t=195499
Hope it helps.
Old Mar 7, 2006 | 05:03 PM
pcmw's Avatar
pcmw
Yeah, those wheel will NEVER fit on Supra brakes. You need a ton of clearance on the outer edge of the factory rotor + 1". If you didn't buy Supra High Disk clearance wheels, you have zero chance of fitting by "luck".
MW
Old Mar 7, 2006 | 05:24 PM
$C300's Avatar
$C300
ya i pritty much gave up all hope for the TT breaks, im just going to get sum nice pads and rotors for now.
Tnx to all for the help
Old Mar 7, 2006 | 09:08 PM
pcmw's Avatar
pcmw
I think they are WELL WORTH IT. In fact, with my 19's on the car, the stock brakes are not all that safe of slowing that unsprung weight at speeds. The Supra brakes are overkill, but cheaper than the next closer alternative.
Get em, get new rims, or supra rims for now.
MW
Old Mar 7, 2006 | 09:22 PM
$C300's Avatar
$C300
< savin for a 1J for now rotors, good pads, and SS lines
Deception
Suspension and Brakes
Dec 14, 2010 08:42 PM
GSspeed
Wheels, Tires & Brakes Forum
Dec 19, 2005 05:25 AM
black86
Jul 20, 2005 12:09 AM
Blue98Gs3
14
Dec 19, 2003 02:24 AM
healerhand
Dec 3, 2002 03:30 PM
