Have you checked the clutch fail safe switch that keeps it from powering the starter if the clutch is not completely depressed? It's either that, or a bad starter/solenoid.
Same thing happened to me on 3000Gt VR4. Took Mitsu like a month to figure it out. Mine was actually a loose wire, that would work one day then not the other. And that was messed up because of the meat-head who put the remote start in wrong
i agree with the starter... my talon had the exact same problem and i had a brand new optima....i mean it could be the clutch switch as well but it sounds more like a starter problem
I had the same problem, where my car would start up perfectly one day and the next it wouldn't start up. It may be the connection in the starter. Before you buy a new starter, have a performance shop check the connections in your starter. You will save a lot more money if you have them rebuild your starter.
