Anybody Have To Experience This?
Old Jan 25, 2005 | 08:06 PM
newyorksc's Avatar
newyorksc
Default Anybody Have To Experience This?
well anyone in the tri-state area knows we got bombarded with snow.
thursday my car was running fine, everything was ok
then it snowed and i didnt try to start my car until monday..
didn't work so i assumed it was the battery
went back today with my brothers car and tried to jump start but nothing
no turning over, no clicking, so im assuming its not the battery.
lights work fine and strong, radio is loud, wndows work fine..
lights on dash dim when turning key but there is no turning over.
what else can be wrong?
Old Jan 25, 2005 | 08:09 PM
aliga's Avatar
aliga
Former Sponsor
starter problem?
Old Jan 25, 2005 | 08:10 PM
SC300Es's Avatar
SC300Es
Smack the starter with a hammer a few times while someone is turning the ignition.
Ed
Old Jan 25, 2005 | 08:11 PM
VSsc400's Avatar
VSsc400
Ed
no joke this works, but try with a rubber mallet instead of metal hammer
or it can be poor battery terminal connection
Old Jan 25, 2005 | 08:17 PM
newyorksc's Avatar
newyorksc
when i turned the egnition key, i didn't hear any clicking sounds (from starter)
i am wondering wether the microswitch at the clutch pedal may be stuck in the open position.
i dont suspect it to be the starter because i do not hear any attempt for the starter to engage the flywheel.
is it common for the interlock microswitch pedal to be stuck in the open position or frozen after cold wether. we had exceptionally cold weather the past few days.
until this cold event, there was absolutely NO problem starting the car.
is it easy to bypass the microswitch?
i thoroughly checked battery connections
Old Jan 25, 2005 | 08:23 PM
newyorksc's Avatar
newyorksc
All help is appreciated. Thank you.
Old Jan 25, 2005 | 08:27 PM
aliga's Avatar
aliga
Former Sponsor
jump the microswitch, splice it together, see what happens.
Old Jan 25, 2005 | 09:35 PM
silversprucesc3's Avatar
silversprucesc3
You should be able to easily check the voltage to the starter...
I believe that will tell u if its getting current... if not then its something else...if so then its your starter...
guys let me know if this makes sense?
Old Jan 25, 2005 | 11:02 PM
Sleeper97's Avatar
Sleeper97
try checking the fuses.
Old Jan 26, 2005 | 09:44 AM
Spencer's Avatar
Spencer
You most likely have a dead spot on your started, mind did this for about 3 months till it finally died. All I would do it just keep turning the ignition till it strated, like non-stop. If you got a 5speed just park it on a steep hill and push start it.
Old Jan 26, 2005 | 06:53 PM
newyorksc's Avatar
newyorksc
Well Ive Got It Working Finally! It Was The Clutch Start Switch< I Had To Manually Apply It>>
bacon22
IS - 1st Gen (2001-2005)
Jan 17, 2012 04:58 AM
Fredrico55
RX - 1st Gen (1999-2003)
13
May 3, 2011 09:47 PM
eternaldj
Sep 17, 2010 02:46 PM
slugmike
Dec 18, 2005 11:00 AM
JadeSCFour
Jul 1, 2004 06:30 AM
