PWR button problem 93 SC4
Old Sep 16, 2005 | 01:02 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Question PWR button problem 93 SC4
Hey guys, as some may have read in the Engine/trans section, I just got a 93 SC4, like it so far, but I’m very surprised with a problem im experiancing, never came across it before. The PWR button does nothing, it does not light up anything in the dash, NOR does the actual button light up in the center stack.
Now, do you think the button is defective? or the instrumentation light is out? (Never seen this happen).
However, I did open it up, and made sure the PWR button harness was connected well, so what do you think is the problem? Just a dash light? and how do I find out without tearing up the dash? (I don’t mind if its not too hard).
Thanks
Old Sep 16, 2005 | 09:20 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Could very well just be the bulb on the dash. Have you tried to compare differences while driving? Try a few starts from a red light, some with switch on and some with switch off. See where your shift points are and compare. Also try some 40+ accelerations with switch in both positions. You should notice different shift points.
Old Sep 16, 2005 | 09:38 AM
RaynArt's Avatar
RaynArt
the 40mph roll def. helps in noticing the difference.
Old Sep 16, 2005 | 09:40 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Good point guys, only problem is, this is car is completely new to me, so its very hard for me to notice the small difference. But I will try it.
Old Sep 16, 2005 | 09:54 AM
RaynArt's Avatar
RaynArt
shouldnt be too hard to tell, the down shift should come pretty quick with the ECT on. also when ur lets say...... half throttle it should run higher in rpm before shifting to the next gear where normally it may shift at 3-3.2k at mus usually.
mkorsu's Avatar
mkorsu
Zombie Slayer
You should be able to watch your tach and see the different RPM point that the shift takes place at.
Old Sep 17, 2005 | 12:40 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
I'm going to try it tommarow, thanks guys.
Btw, isnt the PWR button supposed to light up next to the gear shift on the SC's?
Old Sep 19, 2005 | 05:11 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Anyone?........
Old Sep 19, 2005 | 06:24 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Anyone?........
I only have a light that comes on on the instrument panel in my '92.
Old Sep 25, 2005 | 12:30 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
I dont mean when its engaged, but the ACTUAL button, is it backlit like the gear indicators and the seat warmers?
Old Sep 25, 2005 | 07:11 AM
gadgetSC's Avatar
gadgetSC
The button is not backlit.
gadgetSC-t
Old Sep 25, 2005 | 11:52 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
gadgetSC-t
Thanks......
Old Mar 2, 2006 | 02:42 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
gadgetSC-t
Bumping for future reference, yes it is backlit and there are two small bulbs in it, I saw them today
posterboi
Feb 20, 2022 07:20 AM
Offspring
Aug 1, 2018 09:26 AM
dirtracin1
Apr 2, 2014 04:16 PM
jazz2451
Hybrid Technology
Aug 19, 2009 08:37 PM
Alewifebp
Apr 25, 2002 08:58 PM
