Remote start/tilt steering
Old May 10, 2005 | 04:00 PM
bcp_sc300's Avatar
bcp_sc300
Registered User
Default Remote start/tilt steering
hay guys i just got a Clifford 3.5 and been installing it ,but dont know how to make my tilt steering work when i put my key in, cant find the wire? try searchin but cant find any info for a 97sc3..
thanks guys if u can help
Old May 10, 2005 | 05:37 PM
Fiya's Avatar
Fiya
check out www.the12volt.com those guys are experts
Old May 10, 2005 | 08:25 PM
SSmith's Avatar
SSmith
Everything on my remote start works great except fot this also. What I do in the mornings if the car is remote started is get in, turn the key, hit brake pedal to dissengage remote start, then hit my number (1) preset on the door. Steering wheel come right down, Sounds longer than it really is.
Shane
Old May 10, 2005 | 10:11 PM
inovashn's Avatar
inovashn
mine doesn't work when you remote start it but it works fine when you put the key in. just a quirky thing with all the bypassing and activating the ignition and accessory wires. i just live with it cause i don't want to tear it all down and try to figure it out. i mean it still works fine without remote start.
Old May 11, 2005 | 06:16 AM
CleanSC's Avatar
CleanSC
The auto tilt is activated by the key-in sensor in the ignition cylinder.
If you are doing ANY electrical work on your own car, I strongly recommend the electrical manual. It explains the entire car in color and only costs like $15. It's worth it's weight in diamonds.
It made my alarm install a breeze.
Old May 11, 2005 | 09:45 AM
bmatsu's Avatar
bmatsu
Did you make sure the switch near the steering wheel is on. It is easy to turn off and not know that you did it.
Old May 11, 2005 | 05:52 PM
bcp_sc300's Avatar
bcp_sc300
Registered User
got any info how and where can i get this book??
Old May 12, 2005 | 05:23 AM
CleanSC's Avatar
CleanSC
Your favorite dealer or Carson Toyota.
Old Jan 10, 2010 | 08:38 PM
Mistical's Avatar
Mistical
Has anyone figured this out?
I would also like my steering wheel to come down upon putting the key into the ignition after it has been remote started.
Old Jan 10, 2010 | 09:18 PM
FormosaSC's Avatar
FormosaSC
I just put the key in, and press the seat memory button,
Old Jan 10, 2010 | 09:35 PM
Papajorgio's Avatar
Papajorgio
well heres what i found with my tech support data base,
When doing a remote start...In order for the telescoping
steering wheel to work there needs to be 4 relays installed.
If these are not added, then the customer must shut off the
remote start and restart the vehicle. Relay 1. Locate and
remove 10mm bolts securing the fuse box under the
driver's side under dash. Locate plug 1J, both wires test
12v with the key in the run position. They should be
blue/green & blue with brown dots, but some years vary.
To verify, remove the 20A fuse marked for the wipers (both
wires should lose power in the run position). Cut both of
these wires and tie them together( they both are common
in the fuse box). 87A-blue/green&blue/brown dots (away
from the fuse box). 85-to remote start blue(-)status out
wire. 86-12v. 30-both wires to fuse box side. Relay 2.
Remove the 10mm bolts holding the body ECU located in
the drivers kick. Locate plug B6, pin #9 (red/blue). Ccut the
red/blue wire & interupt with a relay. 87A-red/blue away
from ECU. 30-red/blue going to ECU. 88-12v.85-blue(-
)status from alarm. Relays 3&4. Locate the tilt and
telescoping ECU below the steering wheel. Find the red/blu
thats all that it went up to, but it seems like its really not worth it just to get the steering wheel to move a little...
Old Jan 10, 2010 | 09:45 PM
Scotty's Avatar
Scotty
Like CleanSC said several years ago, all that needs to be connected for the steering wheel to come down is the keysense wire. Which can be connected to a status output of a remote start unit.
Old Jan 10, 2010 | 09:48 PM
Mistical's Avatar
Mistical
Thanks for looking up and providing the info. I will relay this to the installer and see if he can make sense of it.
..if the system can work like it should, why not...
maxtcee
Suspension and Brakes
Mar 3, 2018 10:27 AM
LS400Club
17
Jan 6, 2017 07:43 PM
ebxgsxr
Feb 15, 2013 11:47 AM
VinnyQH
Dec 23, 2009 03:19 PM
