Winter tire options
Old Dec 19, 2024 | 05:25 PM
  #256
BLUKTY2's Avatar
BLUKTY2
Originally Posted by sheetmetalfab
Nokian hakka 10's work amazing.
stainless steel studs with shaped carbides.
great traction even on the freezing rain / ice rink days.
I went with the Hakka's too, now on my second winter with them. So far this ice rink winter has really put them to the test, and they have been great! No regrets with spending the extra $$$ on them.
Old Dec 19, 2024 | 10:31 PM
  #257
eNx's Avatar
eNx
Originally Posted by SKGX
Yes, but it is the configuration of the lug bores of the wheel that determine which type seat you need for a lug Bolt/Nut. I know that a few Toyota and Nissan's used flat seat (called Mag Seat) lug nuts on some models but I have never heard of any manufacturer using mag seat lug bolts. There are obvious torque/strength/mounting advantages and disadvantages to each.
I would not use a ball seat bolt on a mag seat spec wheel.
Gotcha, thanks.
Old Dec 20, 2024 | 11:58 AM
  #258
eNx's Avatar
eNx
Default After Market Wheels doesn't take to account lug bolt vs lug nut?
So after checking some aftermarket wheels, I noticed that the part number for a 2022 RX350 is the same for 2024RX 350 from Drag. Does this mean that aftermarket wheels can take cone shape lug bolt (2024 RX) and whatever 2022 lug nut style is? It does not make sense to me.
https://www.dragwheels.com/wheel/dr-...ed/10159/3540/
Old Dec 20, 2024 | 01:08 PM
  #259
SKGX's Avatar
SKGX
The AL20 Chassis uses the Mag Seat lug bolts. 12X1.5
You are referencing Gen4 OEM wheels in your original inquiry. The OEM wheels are drilled the way that they are from the factory. Now, you can take any wheel with the same mounting specs 5X114.3/60.1 and any manufacturer can drill the lug holes with any mounting spec that they want. If oem took Mag Seat nuts and you purchased aftermarket wheels with cone or ball seat, you would just have to buy 12x1.5 proper seat nuts to make the wheels work.
Your issue is that you are trying to mount the Gen4 OEM wheel to a Gen5 which will be challenging.
Old Dec 20, 2024 | 01:32 PM
  #260
eNx's Avatar
eNx
Yeah, I'm giving up on the gen4 wheels and going aftermarket. Hence looking at those Drag wheels but there no way to specify to make it fit gen 5 RX
Old Dec 20, 2024 | 01:43 PM
  #261
SKGX's Avatar
SKGX
Sure, all that you need are wheels that are 5X114.3 bolt pattern with an offset (range) et36-40. I personally wouldn't go smaller than 20X8.5", but others in here have gone 18" (which definitely would not work with any F-Sport model because of the front calipers). Any aftermarket wheel will likely need a Center bore adaptor ring. Aftermarket wheel vendors mill wheels with a common sized center bore (usually in the 70-74mm range) so that adaptor rings make them usable on a wide range of vehicles. You'll have to buy new lug bolts to match whatever seat bore the lugs are for any given wheel. Check Tirerack for a bunch of affordable options.
Old May 9, 2025 | 07:23 AM
  #262
WellsB's Avatar
WellsB
The Goodyear Assurance WeatherReady2 is now available in the OEM 21" size, giving those of us with 21" wheels a 3PMSF Severe Winter rated option without having to change sizes. I'm at 7/32" on the OEM Bridgestone tires @ 25k miles, so it's looking like they might actually make it to the 40k miles they are rated for. Still hoping the CrossClimate2 will be released before then.
Old May 9, 2025 | 12:38 PM
  #263
Eagleboy99's Avatar
Eagleboy99
I suspect they migh tnever make a 235 in an all weather/winter. The MICHELIN® CrossClimate®2 265/45R21/XL 108V is equivalent.
evident
Sep 29, 2015 01:44 PM
vertcobra9
Wheels, Tires & Brakes Forum
13
Jan 28, 2007 07:22 PM
lxuser
RX - 1st Gen (1999-2003)
Nov 20, 2005 07:02 PM
vtwheels
Oct 31, 2005 10:23 AM
SL730
Nov 5, 2001 06:04 PM
