Winter tire options
Old Nov 29, 2024 | 04:19 AM
  #241
Carbuff2's Avatar
Carbuff2
Originally Posted by GeneralKlinger
It doesn’t snow alot in NJ,
Maybe where YOU live. Try driving in Sussex County some morning after a snowstorm. (Higher elevations and more twisty roads with inclines)
I posted my observations regards lug bolts here:
https://www.clublexus.com/forums/rx-...ght=+lug+bolt+
Interesting design. Makes the interface between wheel and their fasteners unique, though.
Old Nov 29, 2024 | 10:07 AM
  #242
Den49's Avatar
Den49
too late now. 😂. No returns.
it’s fine. If they work, it’s more to make myself feel better. It doesn’t snow alot in NJ,
Wheels have different hub thicknesses. When you get your lug bolts, put one through one of your wheel holes and see how far they protrude. You may get lucky and lug bolt protrudes the ideal 18mm. If not, mark the lug bolt where it protrudes 18mm. Then remove the lug bolt and measure the shank length from the base of the cone to the 18mm mark. That measurement is the ideal lug bolt length for that wheel on your RX and the one to reorder if you choose to do that. Alternatively, you could use the 33mm lug bolts, keep an eye on them for corrosion and replace them if and when you see them getting bad. Good luck and thanks for starting this conversation because it resulted in identifying a source for the black lug bolts I was looking for.
Old Nov 29, 2024 | 11:48 AM
  #243
GeneralKlinger's Avatar
GeneralKlinger
Originally Posted by Den49
Wheels have different hub thicknesses. When you get your lug bolts, put one through one of your wheel holes and see how far they protrude. You may get lucky and lug bolt protrudes the ideal 18mm. If not, mark the lug bolt where it protrudes 18mm. Then remove the lug bolt and measure the shank length from the base of the cone to the 18mm mark. That measurement is the ideal lug bolt length for that wheel on your RX and the one to reorder if you choose to that. Alternatively, you could use the 33mm lug bolts, keep an eye on them for corrosion and replace them if and when you see them getting bad. Good luck and thanks for starting this conversation because it resulted in identifying a source for the black lug bolts I was looking for.
I mean… spending $50 on new bolts each winter is certainly cheaper than spending $1800 on new tires/wheels 😂
  #244
GeneralKlinger
I’m in south NJ, outside of Cherry Hill. We are lucky if we get one 6inch dump 😂
Old Dec 13, 2024 | 02:06 PM
  #245
GeneralKlinger
So figured I'd update this. Finally got the winter tires installed today. No issues at all going down to 18s. Bolts I previously mentioned/ordered work fine. Now... the TPMS sensors do not. I presume because they're generic ones from Discount Tire. Guess I will have to order the Lexus ones.
Edit: just ordered the Lexus OEM sensors from the Scottsdale AZ dealership. $259 for 4 isn't terrible I guess LOL
Old Dec 14, 2024 | 10:44 AM
  #246
wrinkle's Avatar
wrinkle
Let us know, @GeneralKlinger and @Den49 - if you also observe better mileage/efficiency with the 18 inch wheels. The ride quality has definitely improved per Den49's report with the 18 inchers - and the fuel efficiency should too. I'm almost ready to go with All-season 18 inch wheels as soon as I wear out the stock 21 inchers. (I don't need snow/winter tires).
Old Dec 15, 2024 | 08:46 AM
  #247
mrfixitri's Avatar
mrfixitri
Default Have you tried Costco?
Originally Posted by misher
Hey looking at winter tires. The cheapest option I could find was $2500 from Kal-Tire which was a set of steel rims, tires, and the air sensors they have to install. The rims are a different size than what came with the RX but Kal-Tire said they will fit fine just the tire will be thicker.
Lexus quoted me $5000 total, $2250 for these tires and $2250 for the alloy rims.
x4    235/50R21 Michelin XICE Snow
Anyone got a better deal/suggestion? $2500 is a bit much. Will they be quite a bit cheaper in summer? First time buying winter tires.
Costco has a great selection of custom alloy wheels and most higher grade tires. Living in AZ I don't have much use for winter tires. But last year I got top of the line all-season Michelins for $800 installed (balance, sensors, nitrogen all included) for my previous GX. Oh, and lifetime warranty.
Old Dec 15, 2024 | 12:48 PM
  #248
Den49's Avatar
Den49
I haven't driven the RX a lot since I put on the 18" wheels and tires, so it will take a while to determine if there is any significant change in MPG.
Old Dec 15, 2024 | 03:03 PM
  #249
ColoradoDavid's Avatar
ColoradoDavid
Costco beats everyone on price. They include 5 year road hazard in every sale. And use nitrogen - which in cold climates like Colorado - reduces need to fill up tires when temperatures drop.
Old Dec 16, 2024 | 06:02 AM
  #250
GeneralKlinger
I have Winters on, so the ride quality is not as good as stock 21's. It's definitely alot noisier, that's for sure. First thing my wife pointed out.
Old Dec 16, 2024 | 09:03 AM
  #251
sheetmetalfab's Avatar
sheetmetalfab
Nokian hakka 10's work amazing.
stainless steel studs with shaped carbides.
great traction even on the freezing rain / ice rink days.
Old Dec 19, 2024 | 08:26 AM
  #252
eNx's Avatar
eNx
Default 2022 RX 350 20" wheels fitment on 2025 Rx 500h f sport
Hey all, reading through this thread and seeing that gen 5s went with lug bolt instead of a nut. And the lug bore on gen 4s are flat vs cone shape for gen 5s.
Does this mean we can't fit gen 4 winter set with our gen 5? Or maybe find a lug bolt that is flat instead of cone shape?
Old Dec 19, 2024 | 09:45 AM
  #253
SKGX's Avatar
SKGX
As long as the specs are the same (which I believe that they are ), yes you would need to find flat seat lug bolts.
Can't say that I have ever even heard of them, personally. Or, convert them to studs (which I would never do personally).
Old Dec 19, 2024 | 10:34 AM
  #254
eNx's Avatar
eNx
Yeah, not gonna convert a brand new car to studs. It look like Otis has a ball seat bolt too.
https://otisincla.com/product/14mmx1...th-50mm-black/
Old Dec 19, 2024 | 05:10 PM
  #255
SKGX's Avatar
SKGX
Yes, but it is the configuration of the lug bores of the wheel that determine which type seat you need for a lug Bolt/Nut. I know that a few Toyota and Nissan's used flat seat (called
Mag Seat Mag Seat
) lug nuts on some models but I have never heard of any manufacturer using mag seat lug bolts. There are obvious torque/strength/mounting advantages and disadvantages to each.
I would not use a ball seat bolt on a mag seat spec wheel.
