Front hub
Old Apr 9, 2022 | 04:14 PM
Mike813's Avatar
Mike813
Default Front hub
Hello all, anyone have guidance for a DIY on a front hub replacement on our 3rd gens 450/350? I Messed up a seized stud change which resulted in stripping the entire hole where the stud sits in. This mistake will fail Inspection in NY so I need to have it taken care of. The rears look really easy, take off brake components/rotors, a few bolts behind the hub,remove abs sensor plug-and remove and replace. The font however looks like a bit of work?? Any help is appreciated!
Old Apr 9, 2022 | 11:02 PM
Hayk's Avatar
Hayk
The hub replacement requires a hydraulic press or a special hub puller with a powerful impact tool. You will also need a new bearing as it gets destroyed during the hub replacement.
The procedure is the same as any FWD Toyota, so you can search for Camry, Avalon, ES350, Sienna, etc and find a DIY.
You need to:
remove the wheel speed sensor
remove the brake rotor
disconnect the CV axle shaft from the hub
disconnect the outer tie rod end from the steering knuckle
disconnect the ball joint from the control arm
disconnect the strut from the steering knuckle
optional:
remove the ball joint from the steering knuckle
Now you can replace the hub and bearing and put it all together.
I would recommend you bring the car to a shop for this job.
Old Apr 10, 2022 | 05:29 AM
salimshah's Avatar
salimshah
25 Year Member
The bolt portion are replaceable and can be pushed out ands new ones can be squeezed in. If you have mangled the hole for there stud, check with welding place where they can be partially filled in and re-drilled for the stud. Just make sure they take proper precaution and not overheat the bearing.
Salim
Old Apr 10, 2022 | 11:47 AM
Roscol's Avatar
Roscol
Might be easier and cheaper overall to just swap out the knuckle assembly with a junk yard one. When my hub bearings went, I found that so much easier, from a DIY perspective than messing around with pressing out and replacing a hub assembly.
Old Apr 11, 2022 | 06:12 PM
Mike813's Avatar
Mike813
Thanks for all the information! It seems a used/new loaded knuckle might be my best bet. I have access to a few air tools but not a press.
appreciate the help!
Old Apr 11, 2022 | 10:59 PM
Hayk's Avatar
Hayk
There is a hub puller made for Toyota you can pickup on Amazon if you have an air impact wrench.
boss22
Dec 22, 2020 04:30 PM
PureDrifter
28
May 8, 2016 08:23 AM
Reesetrict
Jul 24, 2012 10:49 AM
DRFT103
Dec 2, 2008 07:52 PM
cenwesi
May 7, 2008 01:33 PM
