RX350 Struts/Shock Replacement (merged threads)
Old Jan 3, 2023 | 06:52 PM
  #226
nmehta211's Avatar
nmehta211
Originally Posted by Clutchless
That is way too much money for that job and I too would never trust a franchise repair shop such as Firestone, Goodyear, Aamco or Midas to do this work.
This link may help you find a good local independent car repair shop.
FYI the RX suspension is very similar to millions of other Toyota, Lexus and other Japanese vehicles. Every repair shop knows how to replace struts and shocks, they do it all the time.
The link is to shops recommended by listeners of the Car Talk radio show in which listeners called in for car repair advice. You can enter your city and state. Once you have some likely shops, cross check them on Google or Yelp for more current info as some of the reviews are a bit old.
https://www.cartalk.com/mechanics-files
Thank you--this link is very helpful!
NM
Old Jan 3, 2023 | 09:17 PM
  #227
GknowFotos's Avatar
GknowFotos
NM
Definitely search on Google for shops that might specialize in Toyotas. Good luck!
Old Feb 20, 2023 | 03:57 PM
  #228
DobreRX's Avatar
DobreRX
Default 2010 RX350 strut & shock replacement
1st time poster, long time reader from Chicago...
  • 2010 RX350, purchased, June 2020, 75k; current mileage, 104,500
  • one[1] owner, vehicle serviced, Lexus dealer @ regular intervals
  • all parts, RockAuto
  • Billy B4 front struts[2], L, 22282668; R, 22282675; $86.99 each
    • cheaper than Billy B6, $134.89, $114.79;[3-day delay] KYB Excel-G, $115.89; Monroe, 72766, $116.79; 65, $120.79, Sachs, $85.99
  • KYB, SM5886[2]; $37.99 per mount
  • used original bellows
  • used original springs; indie shop = $286 strut labor
  • MOOG front stabilizer bar end link[2], K90344, $20.89 each
  • MOOG front stabilizer bar bushing[1], K200616, $12.90 each
    • indie labor = $44
  • Billy B4 rear shocks, 19282862, $59.79 each
    • generally cheaper than Billy B6, KYB, Monroe, Sachs
    • buddy labor = $50
  • coolant flush/refill, Toyota 50/50 pink, $32.99; indie labor = $60
  • installing later this year, NGK Iridium IX plugs [#6619, $5.82]; back three[3] plug coils [#48726, $57.79]
    • buddy labor = $250; indie quote = $425; Toyota = $640; Lexus = $840?!
  • Many thanks for the great RX advice!
Old Dec 13, 2023 | 05:20 PM
  #229
cruzer23's Avatar
cruzer23
Originally Posted by MattRX
So I just finished getting all the Bilsteins onto the car! Could I possibly be the first person to do all four? Rears only took an hour for both. Front were a different story... Had to cut off sway bar links and compressing springs is not a fun task. All new hardware for the rear, every... single... bolt. New Moog end links up front complimented the Bilsteins nicely. I ran into issues with the B6 front strut piston bolts fitting on. They were 22mm hex instead of 19mm, so my socket wouldn’t fit in the mount. I would suggest getting new OE ones or equivalent. Thread pitch is M14 x 1.5 with a nyloc insert..
does the OE nut fit the b6 bilsteins? i went to my local ace and checked out an m14x1.5 but its still 22mm
Old Dec 13, 2023 | 06:32 PM
  #230
MattRX's Avatar
MattRX
I used an OEM nut
90080-17217
Old Dec 13, 2023 | 06:37 PM
  #231
cruzer23's Avatar
cruzer23
I used an OEM nut
90080-17217
awesome thanks!
Old Mar 16, 2024 | 12:15 PM
  #232
Rogi's Avatar
Rogi
Hello i want to buy shocks but not sure if it all ok. rx350 2010 awd. Shock form toyota ,Bilstein B4 OE Replacement 14-19 Toyota Highlander Rear Twintube Shock Absorber - Black . Not yelow? Front ill change it later maybe KYB or B4. Thanks
Old Mar 16, 2024 | 04:16 PM
  #233
MattRX's Avatar
MattRX
Fronts have to be from a 2010-2013 Highlander, rears from 2014-2019 Highlander. Don't mix and match brands, either get all KYB or all Bilstein. The B4 (black) are more comfort-oriented, B6 (yellow) are stiffer and sportier.
Old May 7, 2024 | 03:39 PM
  #234
ecstatic1's Avatar
ecstatic1
*_*
Old Jun 2, 2024 | 11:59 AM
  #235
AOmer786's Avatar
AOmer786
6th Gear
Hi Clutchless, I got this from another post of yours where you said it might be a good idea to replace the below. Where can I get these from and for which vehicle that would work for the 2015. rx350
-new front strut mount bearings and only get Toyota ones for durability.
-Maybe replace the strut mounts if you want, and check the strut shaft boots before ordering as they are often ripped.
These are the struts I am ordering
Bilstein 24-282901 Rear B6 Shock Absorber Toyota Highlander
Bilstein 22-282736 Front Right B6 Strut Toyota Highlander
Bilstein 22-282729 Front Left B6 Strut Toyota Highlander
Old Jun 2, 2024 | 04:01 PM
  #236
Clutchless's Avatar
Clutchless
You listed links to Shock Warehouse which appears to have most of them in stock. One of the fronts is on backorder at Shock Warehouse but these guys claim to have it https://www.buybrakes.com/bilstein-2...strut-assembly
Or did you already order stuff? I had a difficult time understanding exactly what you were asking.
If it is where else to shop for these, then try Rock Auto, or Summit Racing, or just Google search the part numbers. It may help to call first to confirm if there are actually in stock before ordering online.
As stated in post 233 above and elsewhere:
​​​​​​Fronts have to be from a 2010-2013 Highlander,
Rears from a 2014-2019 Highlander
Are you doing the install or getting a shop to do it? Spring compression is not for beginners as it can be very dangerous and requires the right tools etc. You also have to carefully watch the strut mount orientation when taking them out and putting them back in to the same position as it affects alignment.
Old Jun 2, 2024 | 04:32 PM
  #237
AOmer786's Avatar
AOmer786
6th Gear
Thanks for your reply,
I wanted to know where should I get these from and for which vehicle? I'll call around to see if someone can put them on for me. Thanks!
1. New front strut mount bearings: Found these on ebay are they correct? ( OEM 2PCS Front Suspension Support Strut Bearing 90903-63014 Fits Toyota Lexus)
2. The strut shaft boots are ripped as well on both fronts. Will these work on amazon? ( KYB - SB102 Strut boot )
Unfortunately, I placed the order from Shock Warehouse already. Wonder if I can cancel just the one thats on back order. 282736 Front right. and order this from the link you shared. from buybrakes.
Old Jun 3, 2024 | 11:27 AM
  #238
Clutchless's Avatar
Clutchless
Just call Shock Warehouse and ask. Then make sure the other guys have it and place an order.
Call around to local independent shops for quotes to do this job. The fronts being struts are more difficult. The rear shocks should just be about 1 hour labor as they just have 2 bolts.
You need an alignment after struts are installed.
The bearing looks correct and the KYB boot should be fine.
Old Jun 4, 2024 | 08:28 PM
  #239
AOmer786's Avatar
AOmer786
6th Gear
Thank you.
After speaking to them they said they just got it in stock over the weekend.
Today, I received the rear shocks and put them in and went for a short drive. Not sure how I feel about them.A bit less boat like ride. Which is good.
Can’t wait for the fronts. Driver side front makes a clunk noice every time I change from reverse then forward or vise versa. Big o tire said that front left maybe bent. Hopefully this fixes it. They wanted to charge me 1100 to do the just fronts with quick struts.
I called a few places and one of them said 28 bucks per strut to rebuilt. Just have to take it off the car and take it to them when the new ones come in.
Old Jun 5, 2024 | 04:20 AM
  #240
Clutchless's Avatar
Clutchless
That is a great price, and very fair, to swap out the removed struts. If you do this, note the marks on the new and old strut mounts so you install them the same way again. There are 3 bolts and marks on the mount to identify which way it points.
That clunk is more likely from a torn front strut mount or bad bearing.
Are you saying that Big O tires said the front left strut was bent? Or the wheel? Or a control arm? It is rare for the strut to be bent unless in an accident and there would be more damage. You need a more reliable source such as a good independent shop to evaluate. If you need help finding one search this database of shops recommended by listeners of the old car repair radio call in show, Car Talk: Then cross check any potential shops on Google or Yelp for more recent information: https://www.cartalk.com/mechanics-files
If you do remove the front struts yourself be prepared to find the front sway bar links rusted on. They may require to be cut off and replaced. This is common if you are in an area with snow in the winter etc.
Almost any brand name aftermarket sway bar link is okay to use to replace the original OEM ones as you will likely never replace them again.
It takes the shocks & struts a few weeks and hundreds of miles to break in and loosen up a bit to ride normally. Do not make a judgement on the initial ride after installation except to note if there are any signs of improper installation such as clunks, vibrations etc.
