Remote start option
Anyone pay less than that? And also does anyone know why it would be so expensive? I've owned many cars and got them all installed with remote starts and the most expensive one was like $450.
Also before someone asks, I did try to use the remote start already (pressing lock twice then holding) tried many times, many different ways... the car doesn't have it.
Genuine: 2 venues
After Market: 2 venues
For the genuine, you can go with the simple remote starter that uses the same car fob. This shouldn't be more expensive than $400 including the bypass module and labor.
Pros: No extra fob. Reasonable in price. Genuine hardware.
Cons: Short range. No 2way capability.
Your second genuine option is the one that was offered to you by your dealership!
As for the aftermarket, although the options are endless, I wanted to point to the major feature that I find impressive which is using a Lexus compatible bypass module that reduces the clutter and it's all plug and play such as this one. The other option is to go with any reliable brand or what's on sale at your convenient location.
It all depends on your real needs.
Secondly, look through some threads and you will find that the OEM issue is not a very good unit. Most say it has little or no range. Same say it will hardly hit outside the window in the driveway.
My son has my Lexus RX350 2010. He went to the local audio shop in St Thomas Ont and got the unit with install in the $250 range. It comes with a small separate FOB. This vehicle has the "credit card" size keyless entry unit so he only carries this FOB. The amazing thing about this unit is the range. He lived in a high rise condo building on the 16th floor and had no problem in starting the vehicle in the parking on 5th level. This is all cement. There is almost no parking lot that he cannot reach even if not in sight. It has been flawless.
I drive a 2015 RX350 and both units are now here in Florida. If interested, I could see if I can get a Model # off his unit or a phone # so you can get a Model #. The paperwork may be back in Canada.
Cheers,
Mel
The video installation looks very easy and straightforward. I dont see it requires any second key fob in the car as well. I am looking to install remote start for my RX350 2011.
Three things to note.
First, the "original" kit sold used the Edge Cellular network and will NOT work since the Edge network was discontinued country wide by all carriers. As such, you’d need to make sure it works on the 4G network. Second, make sure to take a picture of the computer module label before installing it. The module goes upside down above the glovebox. It was a royal pain in the butt install. Third, get yourself an auto trim/plastics puller set (including a fastener removal tool) to remove the passenger-side windshield pillar trim. You have to run the cabling for the Remote receiver that mounts on the top portion of the windshield (in front of the passengers seat). There is a weird clip in that pillar that is designed to pull out so the curtain airbag can deploy but not completely come off. It was even more a of pain to pull because I didn’t have the right tools.Good Luck!David
Some popular aftermarket names might offer near this price.
I have a 2015 RX450H. Have any of the owners of an aftermarket remote start had any issues after installing the remote start? I've called in to 10 local shops around here and none of them have experience with the 450H. They also mentioned some potential complexities or issues because its a hybrid.
I'm currently looking at the Viper DS4VB, 12Volt.Solutions, Compustar models. Any recommendations?
Thanks!
I also have the cell phone remote start option and so far it's the only variant that works on 4g. Compustar and viper versions are only on 3g networks(for Canada) which is disappointing.
I guess it shouldn't be that hard to create something that interfaces with the computer and says (1) I have the key fob in my pocket so I'm legit, and (2) let's go (start/stop button essentially pressed). But what I've never tried is to see just how long the computer runs the engine even if the car is stationary. Enough to heat the water? Or just to top off the traction battery?
