New Daytime Running Lights (LED)
Old Jun 27, 2013 | 07:20 AM
  #76
j0emama's Avatar
j0emama
lookin good!
Originally Posted by StillLine
Curious to see your photos. Check out my new DRL's on the SC.
Old Jun 27, 2013 | 05:21 PM
  #77
MEP7557's Avatar
MEP7557
jOemama
Glad you finally got your lights in. You will need to post pics. I took mine off and had to replace both of those black pieces since I had cut into them. Found some super bright LED's for the OEM DRL's, back to basics.
Old Nov 23, 2013 | 06:52 PM
  #78
ray1628's Avatar
ray1628
Thanks for ur sharing. I followed ur post and did make the lights on.
The problem I have got now is the light is on when the car with no power. When I turn on the car, the LED light goes off.
It is just the opposite for what I expect
Any clue to fix this problem?
My car is 2010 RX450H Limited
Old Dec 24, 2013 | 07:56 AM
  #79
itiramisu's Avatar
itiramisu
Thanks for the write up MEP, this will be one of my to do's when warmer weather comes around next year.
Old Jun 4, 2017 | 07:02 PM
  #80
StillLine's Avatar
StillLine
Default Thread revival
Gonna revive this thread with a couple photos of new drl's added to the RX today.
Old Jun 7, 2017 | 07:54 AM
  #81
vince22's Avatar
vince22
Thumbs up
great job, now it's time to change headlights and fogs to LED's to match the color.
Old Jan 26, 2019 | 12:24 PM
  #82
getitright's Avatar
getitright
10th Gear
Don't want to discourage you, they last 1 year in average. I am trough many sets already. Recently I removed expensive light bars which sucked 16 W each from wife's rx350. They became yellowish and only 3 out of 18 diodes were working. I changed controller after controller , because they had to be 5A or more current wise and Chinese exaggerate the max. current, as usual.
I riveted aluminum plate on the same spot as you, and attached brackets to it , just to understand, that they corrode faster; that's all about aftermarket .
