warning messages
Old Jan 27, 2025 | 07:28 PM
ribster197's Avatar
ribster197
Angry warning messages
Hello all RX350 owners,
i notice that some symbols are showing up on the dashboard (triangle, ABS and the Slippery ) together with 3 messages are displayed on dashboard ( CHECK ABS,CHECK LEVELING HEARDLIGHTS and check AWD).
Does anyone know what is happening ?
Old Jan 28, 2025 | 01:16 AM
703's Avatar
703
obtain a reading of the DTC codes
Old Jan 28, 2025 | 04:39 AM
Clutchless's Avatar
Clutchless
Your 12 volt battery is probably ready to be replaced due to the cold weather speeding up its demise. Low voltage from a dying battery makes many different seemingly random warning lights and codes appear as the sensors are very sensitive to low voltage. A battery can die at any time, no matter how new or old.
So get your battery tested. The big chain Auto parts stores will test for free and if its bad sell you and install a new battery for you.
Old Jan 28, 2025 | 10:19 AM
Joneserdew's Avatar
Joneserdew
6th Gear
Question Threadjacker
We have a 2010 RX350 had it since summer. These errors would pop up and go away. I would check gas cap and seemed fine otherwise. Last Friday car wont start. Cranked but no Fire. Tried to Jump No luck. Removed battery went to Autozone for replacement. Installed. After a few tries started up. Random errors come and go still. Has been fine Sunday and Monday This am no start again I went and tried it and it started fine . I backed out of garage and let it warm up. Turned on and off a few times . Now it is not starting again. Im thinking lose wires? where to start poking ? Battery and Gas cap bad ? The car runs and drives great with or with out the lights on. This is my first post so Im Grateful for any answers I receive. Happy Trails
Old Jan 28, 2025 | 11:41 AM
salimshah's Avatar
salimshah
25 Year Member
Intermittent problems are hard to diagnose, but if a random approach is taken, it adds to the confusion instead of helping.
Gas cap issue should lead to CEL plus code, but typically it does not create start problems.
When jump does not work and if you don't have deadfalls then new battery will not help.
I would suggest invest time in learning or finding the right person to diagnose.
Salim
Old Jan 28, 2025 | 01:05 PM
Joneserdew's Avatar
Joneserdew
6th Gear
Thanks for the quick response
Yes I have a good Guy to take care of it tomorrow.
He has all the tools and such.
I had someone check the Brake lights, moved it in and out of gear , .
I am thinking the Starter may be sticking or the wires are crispy bits for rodents.
I just remembered my 2000 RX300 would require a hammer to the starter sometimes.
Im gonna go try that now .
Update in a Bit Thank you
Old Jan 28, 2025 | 01:29 PM
Joneserdew's Avatar
Joneserdew
6th Gear
Nada gonna get it towed tomorrow unless mystery start and ride under own power. I will update Glad I found this place thanks for doin it
PEACE
Old Jan 29, 2025 | 04:25 AM
2012rx350Ed's Avatar
2012rx350Ed
4th Gear
If you have HID headlights you may wish to check the condition of your Headlight Level Sensor which is mounted under the vehicle near the inside of the rear passenger side wheel. This happened to my vehicle due to a corroded/damaged sensor. This resulted in the display of the same messages and codes. A new sensor solved the problem.
Old Feb 3, 2025 | 03:58 PM
Joneserdew's Avatar
Joneserdew
6th Gear
I had the Pro load the codes and such and many were there. New brake sensor fixed the start issue. New cam sensor was also sending codes. The car seems OK but still has the main computer fault code. My guy says his scanner won't clear it and a trip to dealer will be in order. I am dreading the trip so seeing if any advice on what might happen. Can they refresh a computer? Any similar situations?
Thanks in advance
Old Feb 20, 2025 | 09:17 AM
Riickk's Avatar
Riickk
How/why did brake sensor fix no-start issue? Sounds strange connection.
Old Feb 20, 2025 | 10:44 AM
Joneserdew's Avatar
Joneserdew
6th Gear
the push button needs to know that the brake is pressed down to let the engine start. Having someone check the brake lights from behind can rule it out. New computer was required to erase codes.
Old Feb 20, 2025 | 12:41 PM
Riickk's Avatar
Riickk
.... New computer was required to erase codes.
I gather what you mean is a *different* computer was needed in order to get rid of the codes. I can't imagine spending huge sums to replace a computer when all you need to do is to clear codes in memory.
Old Feb 20, 2025 | 05:40 PM
Joneserdew's Avatar
Joneserdew
6th Gear
The dealer computer could not clear the code . New computer was installed. 1800 including tax US
Old Feb 22, 2025 | 03:37 PM
Riickk's Avatar
Riickk
Tell me you are joking... PLEASE!
kjkcjk
RX - 3rd Gen (2010-2015)
19
Feb 4, 2025 06:15 AM
kreso
Jan 13, 2025 11:13 AM
darylrsv4
Jul 15, 2016 10:34 AM
SAMMVIO2
Apr 23, 2015 01:09 PM
toy4two
Maintenance
Oct 28, 2006 10:17 AM
