Transmission Problem P 0713
Old Nov 21, 2020 | 02:02 AM
Thinn's Avatar
Thinn
Red face Transmission Problem P 0713
PLEASE, I have some problems about transmission when **** changes at RX330. DTC Codes is P0713 Transmission Fluid Temperature Sensor 'A' High Input. Please show me how to fix this problem.
Old Nov 21, 2020 | 01:37 PM
salimshah's Avatar
salimshah
25 Year Member
Before you embark on the sensor replacement, please trace the problem. You may be low on transfluid, or the radiator has leaves or other things blocking the air flow. Another problem can be due to stall speed not working, and that leads over working the torque convertor which results in elevated fluid temp.
So please trace to the source of the problem.
Salim
Old Nov 24, 2020 | 09:33 AM
sktn77a's Avatar
sktn77a
This is the RX300 forum. There were know issues with the transmission in this model that we are all familiar with. Yours is a different model with a different transmission, so you might want to post in that forum to see if any common problems have been observed.
Old Nov 25, 2020 | 08:27 PM
Felix's Avatar
Felix
Check the trans fluid level......Really best to change the trans fluid & filter, sounds like you overheated the trans fluid. A gallon of Valvoline Maxlife trans fluid & a Wix trans filter.....
Old Nov 29, 2020 | 11:35 PM
Margate330's Avatar
Margate330
Hi friend did you figure it out?
What color is the fluid?
Does it smell burnt?
Are you pulling a trailer or boat or going up a steep mountain or anythig overly strenuous when this happened?
Also, do you have trans fluid cooler?
Details please.....
KYGX
GX - 2nd Gen (2010-2023)
Nov 21, 2020 12:30 AM
chrisoberg
GX - 1st Gen (2003-2009)
Nov 11, 2011 05:40 PM
OutlawTita
Maintenance
Dec 2, 2005 03:46 PM
jaisonline
Sep 18, 2002 08:19 PM
