deactivate the auto lock feature
Old Jul 30, 2018 | 07:20 PM
BradRX330's Avatar
BradRX330
Default deactivate the auto lock feature
This sound like the right method for an rx330 ?
  1. Put the key in the ignition and turn it to on.
  2. Press the Unlock button three times.
  3. Turn the ignition off.
  4. Press the Unlock button three more times.
  5. Turn the ignition back to on.
  6. The horn should beep once. This tells you that you’re now in programming mode.
  7. Press the Unlock button, then press Lock again. The horn will beep once to tell you that Auto Lock was deactivated. It will beep twice if you’re reactivating the system.
  8. Turn the ignition back to off and listen for the horn to beep one time confirming that the programming was accepted.
Old Aug 7, 2018 | 08:57 PM
professorm's Avatar
professorm
I found mine in the manual. I just followed the steps, but it was something like that.
I enabled auto lock after after driving a certain speed, and disabled auto-unlock.
Old Aug 8, 2018 | 04:53 AM
BradRX330's Avatar
BradRX330
Oh oh hey thanks I'll look into that
puckhead85
Aug 19, 2013 04:38 PM
Lohus
Feb 9, 2010 07:27 AM
manderson
GX - 1st Gen (2003-2009)
Jan 13, 2010 12:04 PM
icyfreakas
Sep 26, 2009 12:51 PM
sahara78
Apr 10, 2008 07:34 PM
