RX350 Front Rotor bolts
Old Jul 11, 2010 | 06:57 PM
Hayk's Avatar
Hayk
Default RX350 Front Rotor bolts
Does anyone know what size bolts I need, to remove the front rotors? I tried searching and couldn't find anything for the RX but other Lexus models seem to use 8mm bolts.
Also, if I had my rotors turned, would it matter what kind of lathe I used? And what is the minimum thickness for the front rotors?
Thanks
Old Jul 12, 2010 | 06:49 AM
mandyfig's Avatar
mandyfig
I had a write up for brakes. Check it out. Also if you search "brakes," lots of info.
Old Jul 12, 2010 | 08:40 AM
ftw's Avatar
ftw
Are you referring to the caliper bolts? If so, I believe they are a 19mm. As for turning the lathe should not matter if you are having a brake shop doing the work. The minimum rotor thicness you can look it up in the owners manual. Get yourself a big braker bar to help loosen them up. Spray them with some oil first to help.
Old Jul 12, 2010 | 08:50 AM
Hayk's Avatar
Hayk
I don't have an owner's manual, that's the reason I'm on this forum. I used to have AllDataDiy.com for the RX but not anymore (if I remember correctly the minimum was 18mm) I'm asking about the bolts that go into two empty holes on the hub/rotor mating surface. They help you get the rotor off.
Like the holes circled in red here. (this is from an LS400 brake guide)
https://www.clublexus.com/gallery/data/500/tut4ff.jpg
The guide suggested 8mm bolts, I read in another thread where someone suggested to use the 12mm bolts from the Radiator support.
Old Jul 12, 2010 | 11:09 AM
salimshah's Avatar
salimshah
25 Year Member
18mm is almost comparable to the socket size for lug-nuts [25.4mm ~ 1"]. 8mm is more likely to be the right size. Unless you have rust on the hub, the rotor should practically fall off.
Salim
Old Jul 12, 2010 | 08:27 PM
Hayk's Avatar
Hayk
Salim
I meant the minimum thickness of the front brake rotors is 18mm (if I recall correctly), not the size of the bolts. Thanks
Old Jul 13, 2010 | 04:53 AM
tomit's Avatar
tomit
Minimum thickness may be stamped on the rotor rim (rusty part).
Old Oct 4, 2010 | 10:54 PM
Hayk's Avatar
Hayk
Does anyone else have some answers for me?
Old Oct 4, 2010 | 11:32 PM
salimshah's Avatar
salimshah
25 Year Member
Even though I was excluded by "any one else" ... Standard is 28mm and min in 26mm.
Salim
Old Oct 5, 2010 | 12:14 AM
Hayk's Avatar
Hayk
After more research, I figured the bolts I need are 8mm by 1.25mm(pitch). Thanks for the info, salimshah
Also, does anyone know the torque specs for the caliper-bracket bolts and the smaller caliper bolts?
vwynn
May 1, 2008 01:04 PM
ta1972
Suspension and Brakes
Oct 9, 2007 11:55 PM
Witman40
Jan 18, 2007 01:14 PM
TriniLex
Aug 9, 2005 07:12 PM
hellasboy
Apr 30, 2002 02:45 AM
