For some reason, I can hear people fine using the SUV but the people I'm talking to says they can barely hear me...is there a way to increase the Mic volume for the people I am talking to? Thanks in advance
Hmm...Not sure about turning up mic sensitivity, but you could try talking into the mic itself to see if that helps. It's located at the top by the cabin lights.
From the initial screen, hold Info button while turning the lights on and off 3 times. This will bring you the hidden service menu where you can adjust the microphone volume.
Interesting. What other options can be adjusted from this menu??
i only looked at bluetooth which is where you can adjust the mic, it's set at 0 and I changed it to 5 which is the max, I saw nav 4 or 5 other screens you can set into.
Did you try calling anyone to see if it may any difference or not?
Sure did, still sound like I'm talking in a tunnel but it was clear enough and they didn't ask for me to speak loader
Thanks Bongos. I only turned it up to 2, so I will go back and change it to 5. I was afraid I might blast them out if I went to high.
BTW, I had increased the sound of the speaker at first, but that was very loud. So I decided to leave at zero, which I assume is the default. Anyway the speaker sound the same as it did before.
