Bought used '04 RX330 in February with 32k on odometer. Had two(2) front brake/rotor jobs by then. Car now has 37k and front brakes are grabbing causing very bad front end chatter and apparently needs another front brake job with new calipers. Anyone else having same/similar problem????? Your resolution?? Our car is certified used. Took car to dealership this a.m. Tested it and could not duplicate the problem so nothing was done. Am calling Service Mgr. Monday a.m. and will call Lexus Customer Service if no satisfaction. If no replacement of parts is offered am going to trade car and will NOT be getting another Lexus. Wife was going to trade her '01 GS430 on a new IS350 but will NOT either . We can live without Lexus! Any suggestions would be appreciated. Thanks...Loubob
Replace the rotors. With two or more grinds on them they are bound to be defective.
Replace the pads
Replace the shim kits and anti raddle clips
Replace the brake fluid
Replace the brake calipers, front
Test the anti lock brake pump and solenoids
Test both pressure cylinders and if indicated replace the master cylinder
Brakes can be fixed if tested properly. You may be living with a part problem since the vehicle was new. You need to insist the time and skill level is applied to your problem for a resolution; not a symptom fix.
Thanks for the info.
Took the car in Sat. They had their 'best' tech take it out to try and "duplicate" the problem. Could not do it and sent me on my way.
I plan on calling the serv. mgr. tomorrow and giving him 1 more chance to prove themselves or will call Lexus service. Depending on that outcome, I may be buying a new non-Lexus car.
Which Lexus service department is this? I see that you're based out of New York so I'm curious as to which service dpartment you're dealing with.
There's a TSB out on this - it seems that somewhere along the line somebody overtorqued the lug nuts, warping the rotor. It may have been a factory defect, but may have been done by one of the dealer's flat-busters when rotating tires during regular service.
The solution is to replace, not machine, the rotor. Having been machined twice there probably isn't enough metal left to true up the rotor properly. A proper service writer should understand this problem instantly - it is a known issue with some RX 330s - whether they can duplicate the condition or not.
I found my RX's front rotors chattered badly when the brakes were applied fairly hard at speeds above 50 mph. I told this to the service writer and he replaced the front rotors and pads without any additional information. In warranty and with no questions asked.
If you have further problems, find another dealer - or call the Lexus Customer Service (number listed on FAQ thread).
I knew it was rotor. But by just over torque bolts.......
Lots of old-school flatbusters use pneumatic impact tools that can produce as much as 600 fl-lbs of torque - unless they are properly set. Some guys think that unless the torque limit is set to max, the tool isn't fast enough - or "macho" enough for them. Problem is, when the wrench stalls out they can't get off the trigger fast enough. Add to this "chasing" the bolt pattern around the hub, rather than using the approved "star" pattern working across the hub, and you have a recipe for a seriously messed-up rotor.
Unless your ride of choice is a Kenworth, don't let anyone with an air wrench near your wheels.
