Driver's door window switch
Old Apr 25, 2025 | 11:54 AM
Arcadian's Avatar
Arcadian
Default Driver's door window switch
Looks like we need a driver's door window switch. I am shocked to see it's $1,500CAD and even $957CAD from Rock Auto. Anyone know if there's a fix for these switches?
Old Apr 25, 2025 | 01:21 PM
MattRX's Avatar
MattRX
Junkyard?
I don't know of a fix, but maybe you can find some leads here: https://www.toyotanation.com/threads...32102/#replies
I compiled a list of every car that uses these switches in one form or another. If they are compatible or not, that I am not sure. However, I wouldn't be surprised if they were
Old Apr 25, 2025 | 06:13 PM
cdnewton's Avatar
cdnewton
A lot on eBay for less than $100 (used of course)
One example: eBay item number:135529387965
Old Apr 25, 2025 | 06:50 PM
Leeper's Avatar
Leeper
I find such things easily at Pick-a-part for very cheap and I live in a pretty small city
Old Apr 30, 2025 | 04:17 PM
tmakogon's Avatar
tmakogon
We don’t know your symptoms. What seems to be the problem?
Maybe you don’t need a switch after all.
I will assume that driver window opens and passenger/back windows don’t. You need to retrain each window by lowering and raising it from its own door switch. After that, all four can be controlled from the driver door switch.
Old May 2, 2025 | 07:50 AM
Joyous56's Avatar
Joyous56
i didn't write the OP, but you solved my problem! Thank you saving me a ton of money!
My next task is to fix the nonfunctional seat heaters. I'm going to start with checking the fuse. Never had 'em before, not sure I miss 'em.
After that, it's the broken antennae which means I don't get my AM talk shows. Nothing urgent.
Old May 2, 2025 | 08:55 AM
Leeper's Avatar
Leeper
Don't want to hijack this thread Joyous... i faced a long tenuous seat heater challenge go do a search under my name here OR private mesage me I can steer you in the right direction on how to diagnose it to see if it is the element or something upstream. If it is the seat heater module I have a spare here
Old May 2, 2025 | 01:32 PM
Joyous56's Avatar
Joyous56
Thanks Leeper. I see comments where owners can tell that there's power going to the seat heaters. I don't even know how to do that. Many thanks, and I will search your posts.
bullrider
Aug 21, 2024 06:13 PM
Phil01
RX - 1st Gen (1999-2003)
Jan 21, 2023 02:28 PM
timkoss
Mar 5, 2021 02:16 PM
russ29
Jun 26, 2003 02:06 PM
