Drivers door window switch
Old Dec 31, 2022 | 11:33 AM
Phil01's Avatar
Phil01
Default Drivers door window switch
Sometimes when I press the driver's door window switch the window will go down part way and stop or go all the way down. I then press the switch to go back up, but it doesn't respond. If I keep fiddling with it, it finally goes back up. Any ideas on what is causing this? Is it possible to buy the window switch?
Old Dec 31, 2022 | 11:46 AM
maxSteel's Avatar
maxSteel
The switch is part of a control unit. There are some threads about replacing the relay on the control unit.
Check out the video on this post: https://www.clublexus.com/forums/rx-...ml#post9293948
Old Jan 12, 2023 | 12:25 PM
dchan865's Avatar
dchan865
I had similar problem couple years ago. After replacing the relay, that fixed it. I got it from Amazon.
[size=13px]https://www.amazon.com/gp/product/B07C58B3YV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1[/size]
Old Jan 12, 2023 | 05:45 PM
Phil01's Avatar
Phil01
It looks like between these two replies I should be able to fix this. Thank you both.
Old Jan 21, 2023 | 02:28 PM
Phil01's Avatar
Phil01
I got the relay but I am thinking of getting a switch assembly at PnP so I can put that in there while I fix the original unit. If I do that will everything still work if the switch assembly is good from PnP. Right now, it seems like all my projects take a few days to do due to more projects than time.
bird333
Oct 17, 2022 10:33 AM
dbfire
Mar 19, 2022 05:20 PM
Mr177
Sep 4, 2018 10:32 AM
enio45
Jul 25, 2011 08:26 AM
pwesseler
Dec 11, 2008 12:35 PM
