interior mechanical issues
Old Mar 5, 2021 | 04:51 AM
timkoss's Avatar
timkoss
Default interior mechanical issues
first there is slap when you shut the drivers side door with window partially closed. also a little slap when you first roll down window? fix?
2nd.. front passenger window won't roll down at passenger side door switch but it will from driver side window switch?
Old Mar 5, 2021 | 02:16 PM
BaconLS430's Avatar
BaconLS430
The second issue is likely a faulty window switch at the door. You can swap the switch with one of the rear door switches and see if the problem follows the switch.
TXFM
Sep 7, 2024 10:12 AM
AichiBorn
Mar 10, 2021 12:59 PM
Begno
May 3, 2011 08:17 PM
tofu_house
May 28, 2005 01:55 PM
