Tpms issue
Old Sep 15, 2024 | 01:49 PM
toonkev667's Avatar
toonkev667
Default Tpms issue
I have 2009 lexus rx350 and still having tpms warning light flashing after changing all 5 sensors. I have c2126 dtc on my dash. What should I do? Thanks guys
Old Sep 15, 2024 | 01:56 PM
lexo98's Avatar
lexo98
Who replaced them and did they reprogram the ECU?
Old Sep 15, 2024 | 03:50 PM
toonkev667's Avatar
toonkev667
I went to mechanic tyre shop and got all 4 sensors replaced. They programmed the sensors using their tool and put all sensor ID but c2126 still on
Old Sep 15, 2024 | 03:59 PM
lexo98's Avatar
lexo98
If you have a button for the main/2nd tpms sensors make sure that is in the correct position. If that’s ok have them program the ids into the ECU again. DO NOT TURN the car off and have them rescan each sensor again in this order Left front, right front, right rear and left rear.
Old Sep 15, 2024 | 05:23 PM
toonkev667's Avatar
toonkev667
I put it on main and registered it again but it is still showing me c2126 dtc...
Old Sep 15, 2024 | 09:27 PM
lexo98's Avatar
lexo98
Can you explain how you “registered”
Old Sep 16, 2024 | 04:46 PM
toonkev667's Avatar
toonkev667
So basically after installing new sensors, I registered through techstream using tpms module. I put it on main and re registered all id's. I tried deleting dtc too but it came up as soon as I deleted them.
Old Sep 16, 2024 | 06:56 PM
lexo98's Avatar
lexo98
It’s common for the light to come on after entering in the Id’s. Don’t turn the car off and go for a drive. The ECU is waiting for the sensors to send out a signal. Once the ECU receives the signal the light should turn off.
Old Sep 17, 2024 | 08:59 AM
lexo98's Avatar
lexo98
https://www.dillvalves.com/wp-conten...RL-A1257-1.pdf
Old Oct 3, 2024 | 11:19 AM
NickyBlackRCF's Avatar
NickyBlackRCF
4th Gear
Sensors need to be triggered for them to be active.
rygar
16
May 22, 2024 08:20 PM
bswhitener
Jun 15, 2023 07:18 PM
elysium
May 7, 2022 09:09 PM
Kingtut89
Jul 16, 2021 08:03 AM
iSuxeL
Jul 7, 2009 08:14 PM
