Last edit by: IB Advertising
Browse all: Exterior Guides
- How to Replace Your Car Window
Step by step instructions for do-it-yourself repairs
- How to Replace Your Power Window Actuator
RX300: DIY door lock actuator fix write-up
I know this is a repeat post, but worth reminding ...
Do not close the door panel without first confirming everything is working.
IT WILL BE A PAINFUL EXPERIENCE IF THE DOOR FAILS TO OPERATE ONCE CLOSED SHUT WITH THE FRONT PANEL IN PLACE.
Salim
Salim
Unfortunately I found this post too late. I bought from nooelec https://www.ebay.com/itm/163358996752 and it is indeed reversed. Yay
Normally I don't recommend this, but since maxsteel you are way advanced DIYer, you can reverse the wires or flip the magnets in motor (not sure if it is possible). Getting the right product is always the best, but once a while we have to find a solution with things at hand.
Salim
Salim
Salim
Salim
SeattleGS400
Feb 1, 2022 01:04 AM
Alex818
Jan 25, 2017 05:44 AM
MPLexus301
Oct 9, 2009 10:07 AM
