Sporadic Shift Issue
Old Mar 29, 2026 | 05:45 PM
Kazieslexi's Avatar
Kazieslexi
Default Sporadic Shift Issue
Hello All,
I was wondering if someone can help me with an issue i’ve been having with my 2003 Lexus Rx300 with 164k which i’m the 2nd owner and i purchased from a friend who bought it new and had always maintained it well. The issue i started to have recently doesn’t happen every time but when it does it’s aggravating. When i press brake pedal down to shift into drive the shifter doesn’t move. it’s locked. i have to try a few times in a row pressing brake pedal fully or just partially and trying to engage shifter. usually after a couple attempts it works. i have noticed a click sound under dash like a relay or something when i press pedal and go to move shifter. Has anyone else experienced this issue and know what causes this ? just want to know if there is something starting to slowly wear out and will need replacing that i can tackle now?
Thanks In Advance!!
Old Mar 29, 2026 | 06:59 PM
maxSteel's Avatar
maxSteel
See if this helps: https://www.clublexus.com/forums/rx-...ing-again.html
Old Mar 29, 2026 | 10:24 PM
salimshah's Avatar
salimshah
25 Year Member
Owner's manual is a good read.
/It has information about a slotted plastic cover next to the shift lever. This cover can be popped out with a flat screwdriver and it will expose the shift interlock which can be pushed down to free up the shifter.
Salim
Old Mar 29, 2026 | 11:37 PM
Kazieslexi's Avatar
Kazieslexi
Default sporadic shifter locks up
Salim
Salim i will check that out Thank You
Thedadfather
Dec 6, 2024 02:08 PM
ajahearn
Jun 14, 2024 09:56 PM
newnthused
Jul 16, 2023 05:42 PM
mcnelson
Maintenance
Jan 9, 2003 06:43 PM
