stumbling, running rough
Old Apr 7, 2010 | 08:33 AM
exit8a's Avatar
exit8a
Default stumbling, running rough
My '02 RX is missing when driving, running rough, even occasionally stalling. Starts right back up though. Warm or cold. At cruising speed, it'll be ok for the better part of a minute, miss once, then be ok for another time. Problem started all of a sudden. 113K miles. Plugs replaced recently. Odd thing is that the CEL has not come on.
Old Apr 7, 2010 | 09:33 AM
salimshah's Avatar
salimshah
25 Year Member
What make/brand of plugs did you use?
Salim
Old Apr 7, 2010 | 12:02 PM
hypervish's Avatar
hypervish
I agree with Salim it would be helpful to know which brand plugs were installed. Bosch plugs have caused problems for others in the past.
Old Apr 7, 2010 | 02:10 PM
1nablxsonr's Avatar
1nablxsonr
Our 99 FWD had 127k when we got it, at present 132k. Unsure if previous owner replaced plugs. What brand and type of plugs u'all recommend installing? Aftermarket or OEM?
Old Apr 7, 2010 | 02:22 PM
hypervish's Avatar
hypervish
I would recommend installing NGK Iridiums.
Old Apr 7, 2010 | 02:28 PM
exit8a's Avatar
exit8a
Default reply: thanks for the interest...
plugs were dealer installed, no idea what kind. Didn't want to muddy the water, but my engine got the dreaded oil sludge. Oil consumption went way, way up. Through the magic of the internet, I discovered that there was a class action lawsuit and settlement wherein Toyota (Lexus) agreed to fix the problem. So the dealer cleaned out the engine, sent at least one of the heads out, and put it back together. Asked me if I wanted to replace the plugs, which said ok to ($20 per plug). Ran flawlessly for 1,000 miles, then all of a sudden, blech.
Old Apr 7, 2010 | 02:47 PM
hypervish's Avatar
hypervish
If they were dealer installed then they are most likely OEM and I think some dealers did install NGK's. You mentioned in the first post that there are no CEL's but have you checked for pending codes; it may be possible that one of your coils just died. Have you replaced any coils previously?
Old Apr 7, 2010 | 02:52 PM
Nad1370's Avatar
Nad1370
No brainer here.---Go back to the Dealer and let them figure the problem out.
There are a lot of possibilities that can cause your issues in which it's hard to diagose since it just had major engine repair done to it.
Don't understand though why only 1 head was sent out to be cleaned.
Old Apr 7, 2010 | 02:56 PM
exit8a's Avatar
exit8a
Thanks. I'll try to get somewhere to read the codes. Right now I'm in the Outer Banks, NC. On an island. The best recommended mechanic is completely booked. The nearest Auto Zone kind of free code reader is way far. I never knew there was such a thing as pending codes.
Well, another factor is that I'm on vacation, 650 miles from home.
Old Apr 7, 2010 | 03:19 PM
salimshah's Avatar
salimshah
25 Year Member
Call the nearest Lexus dealership and let them check it out for you.
Salim
Old Apr 7, 2010 | 06:55 PM
sktn77a's Avatar
sktn77a
Try to get back home and take it to the dealership that did the work. It almost certainly likely to be related to the recent repairs.
Sturds
Aug 23, 2012 09:55 AM
Ishinc
Jan 24, 2011 09:55 PM
razgs300
Nov 2, 2010 11:33 AM
horent135
Maintenance
Sep 30, 2010 12:41 PM
Lvangundy
Sep 11, 2002 09:46 PM
