Steering Amount Reader on gForce Meter
Old Dec 28, 2017 | 03:32 PM
reyrey127's Avatar
reyrey127
Default Steering Amount Reader on gForce Meter
Recently had an alignment performed because the steering wheel was cockeyed to the right. But now the steering amount reader in the gforce meter is off because when the steering wheel was straightened, now the reader indicates left turns quicker vs right turns of the steering wheel. Is there a way to reset the steering amount or even zero it after the alignment?
Thanks in advance.
Old Dec 29, 2017 | 06:01 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
You need Techstream to do this.
Old Dec 31, 2017 | 08:00 PM
reyrey127's Avatar
reyrey127
Which option or category in Techstream is it located because The dealership could not locate it.Thanks.Rey
Old Jan 1, 2018 | 07:21 AM
lexusrus's Avatar
lexusrus
What???!!! Lexus DEALERSHIP CAN NOT figure this out???!!! Ask them to call Lexus dealer support!!!
Old Jan 1, 2018 | 09:27 PM
Suburbazin's Avatar
Suburbazin
I'm surprised they've never recalibrated a steering angle sensor before.
Old Jan 1, 2018 | 11:29 PM
reyrey127's Avatar
reyrey127
They said they would try calling Lexus technical support after the new year so i guess i will wait. I was hoping someone knew soni could just tell them. Thanks.
Old Jan 2, 2018 | 04:47 PM
lexusrus's Avatar
lexusrus
Hummm, that Lexus dealership just DID NOT provide EXCELLENT SERVICE!! Someone at the Lexus HQ dealer support must be on call. And if one of the Lexus dealership called and no one knows the answer I am fairly certain there's SOMEONE "on call" to get hold of "someone" who knows the answer (even if Lexus HQ needed to call someone in Japan!!)
Old Jan 2, 2018 | 10:32 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
The procedure is called: ROTATION ANGLE SENSOR INITIALIZATION AND TORQUE SENSOR ZERO POINT CALIBRATION
It's in TIS. If they can't figure this out, are you sure you want them working on your car? It took me 2 minutes to find this in TIS.
There is also a way to do this with a shorting wire in the DLC connector, but it's WAY easier with Techstream.
Old Jan 3, 2018 | 07:26 AM
reyrey127's Avatar
reyrey127
Nice. Thank you Lobuxracer! I don’t know anymore now that you said what you mentioned. I will let my service guy know what you mentioned. I had a feeling it couldn’t be that difficult but literally he showed me the menus and not sure what it was under. He recalibrated my torque vectoring ot torque something hoping to fix the issue but it didn’t. Not sure if that is the same thing you are mentioning. During that procedure, the steering wheel was turning on its own when he did the calibration but after that procedure the gforce meter didn’t zero out the steering amount still.
Old Jan 3, 2018 | 07:29 AM
reyrey127's Avatar
reyrey127
Which dealership do you go to in California for service that has provided you Great service? Any recommendation? I am in SoCal.
Old Jan 3, 2018 | 07:46 AM
lexusrus's Avatar
lexusrus
I'm a long time Longo Lexus customer since 2000.
Which one did you go to?
Old Jan 3, 2018 | 04:24 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
That's the torque sensor calibration. The rotation angle sensor is the one causing your issue.
Old Jan 4, 2018 | 12:12 AM
lexusrus's Avatar
lexusrus
BTW, when I had my new all seasons tires put on at a Firestone store last November, I had them do an alignment too. All ok. No problems with the g force sensor.
Old Jan 4, 2018 | 12:19 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Lexus FSM requires zero point calibration after any alignment. If it works out for you, fine, but if there are issues, that's the first thing to check and reset.
Old Jan 4, 2018 | 12:58 AM
lexusrus's Avatar
lexusrus
Cars these days are getting more complicated.....
